Can the banjo bolt without the check value be used for the PCV system? Reviews seem to indicate the check valve is unnecessary.
Volvo PCV Banjo Bolt - Genuine Volvo 8653884
https://www.fcpeuro.com/products/volvo- ... 70-8653884
2007 S60 2.5T To Banjo With Or To Banjo Without Check Valve Topic is solved
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- MoVolvos
.chrism wrote: 15 Mar 2026, 15:06 I’m thinking the check valve acts to protect the PCV system in the event of a bad engine backfire.
Not sure how that works to protect it. Can't remember when I had an engine backfire so don't think that is the main reason for the check valve.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Ah-ha. That would make sense. Thanks.pobracara wrote: 15 Mar 2026, 16:13 The check valve prevents pressure from escaping from the intake manifold to the crankcase when you are in boost mode
So naturally aspirated engines don’t have it?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
pine hollow diagnostics on youtube had a volvo where the ball bearing from the banjo went through the engine, they found it on the FOD screen in the cat converter, it chipped an exh valve on its way out , besides a misfire it drove for 50K miles before the valve burned up.
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 67 times
- Been thanked: 93 times
My Titanium grey metallic 2007 S60 2.5T lost its PCV check valve guts before I purchased the car at 223,901 miles. The parts went into cylinder 3, damaged the head, valves, piston top, and then destroyed the blades on the hot side of the turbo. I replaced the head, piston 3, and finally the turbo. The car now has even compression and drives great.
I replaced the PCV check valve first thing on all the other turbo Volvos because I don't want to replace any more pistons, heads, or turbos. Make sure you replace any of the old PCV check valves with a rolled lip with the new style.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
