Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
scot850 wrote: 15 Mar 2026, 23:58 Are you sure the steering wheel is off? Check if the turn signals cancel at the same point when turning. It could be you fitted the wheel off by one or 2 teeth on the splines.
The wheel is off half a teeth. I tried moving it over a teeth, then it would be even more off, but this time to the right.
1/2 a shitbox V70 1998 2.5 NA
Chieber
Post by Chieber »
MoVolvos wrote: 15 Mar 2026, 15:00
Chieber wrote: 14 Mar 2026, 07:30 Spoke too soon.
I need an alignment. The steering wheel is off.
Had an alignment not even two months ago…
Maybe I’ll try turning the tie rods even turns and see if that works.
Just turning the tie rods evenly may not do the trick. Regardless which way the steering is off you need to measure the Toe to see if it's Toe In or Toe Out with the steering wheel centered before deciding which Tie Rod(s) to turn. Use trash bags under the wheels for less friction and with engine running when centering the steering for measurement. Depending if it's Toe In or Toe Out and which way the steering is pointed left or right while driving you can determine which Tie Rod to adjust.
I found this post by cn90, which says which side tot turn tie rods.
Should be fine like this, not?
Been thanked: 4068 times
CIK7 wrote: 15 Mar 2026, 14:24
abscate wrote: 15 Mar 2026, 10:21 Rolled the S70 Karla to EWR for a ten day trip.
30 mpg , no traffic on Sunday. Stopped and fixed SIL golf on the way.
Are you still in Europe?
On the other side of the planet in Shanghai
Chieber , I think the side marker harness drops from the top harness, not from the front. I grabbed a picture of it when I pulled one from a wreck yo make a 1998 ECT harness from it.
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
I have my 95 850 posted in classifieds.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
RedBrickCollector wrote: 16 Mar 2026, 08:54 Finally took a peek to see why my fender light isn't working after a small repaint a bit ago.
I have no idea where the wire for it is. Should it be coming from the front singal or is it from the door area?
Pulled a fender off for you…. :D :D :D
CIK7
Post by CIK7 »
abscate wrote: 17 Mar 2026, 13:08
Hey whatever happened the s70 (tosh)? I am interested in her.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I love the spring/hinge system of the P80.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
GreenVolvoGoldenDog
Year and Model: 2000 V70 XC
Has thanked: 9 times
Been thanked: 3 times
Post by GreenVolvoGoldenDog »
Hello, long time lurker - first time poster.
I’ll keep it brief since I am just looking for information — I am missing ONE of the three CBV 10mm bolts which are required to replace the cover.
2/3 are accounted for, and the last one has vanished. Made sure it’s not anywhere in the snail, but I have had no luck locating. Tomorrow I’ll go to a junkyard to try and pull it from a P2 I saw today.
Does anyone know the measurements of those 10mm CBV plate bolts? (Pictured current state of CBV, with only 1 bolt in place)
spool
sneeze
1994 Volvo 850 NA Sedan (2022–2024) (sold)
1998 Volvo S70 T5 FWD (2020–2024) (sold)
2000 Volvo V70 XC AWD (2025–∞)
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Welcome fellow desert dweller -
It's been awhile since I've had one of those off, but from what I remember they are short; maybe 1/2" - 1.5 cm.
You could take that one that you see off, and match it at the local hardware store, but I'd inclined to just hit the local yard and grab that bolt, as well as a few other odds and ends.
1999 V70 GLT
The path to follow here is…
Use Volvo parts online website to pull up the turbo diagram and get the Volvo part number
Use Skandix.de who puts dimensions of Volvo part number hardware into the description, like m6x30mm
Having put these things back in under hood, I appreciate why you don’t want to remove one to match. That’s an ugly job of no space tooling.
