Properly Reading/Adding ATF to V70 T5 2001
Noie
Year and Model: 2001 V70 T5
Post by Noie »
Thanks for all of the advice. Finally able to post pictures. This was my fluid level doing the hot check. When I checked in the summer it was at the hot mark. No evidence of any leakage. Just wondering if it is advisable to add some fluid?
Been thanked: 4065 times
Just a bit , like 250 ml. You don’t want to over fill
Do you have the neutral stop feature in your car? Does the transmission slip into neutral when you stop the car at a light?
That’s a special 2001 year only software that the dealer can remove , it was problematic in about 10% of cars
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Given the color, a few drain&fills is recommended :)
Noie
Post by Noie »
abscate wrote: 01 Apr 2026, 02:12 Just a bit , like 250 ml. You don’t want to over fill
Thanks, I will put a little in then when I get the fluid.
Based off of what I've read online, there being a hesitation on acceleration coming out of stops, I think it already has the software as there is no hesitation. It was serviced at the dealership up until the 2013-2014 time frame.
Noie
Post by Noie »
vtl wrote: 01 Apr 2026, 04:52 Given the color, a few drain&fills is recommended :)
I did actually drain and fill it 4 times this past summer. It took about a week to do it all properly. The fluid still came out largely black but had a more red tint to it and was slightly less opaque on the corners of the container I used. Frankly not sure if it was ever done prior to that and it is at 266k miles, so I might perform the same thing again this summer or take it into a local volvo mechanic for a powered flush. I heard flushing can be harmful to the old transmissions though. :lol:
Has thanked: 311 times
Been thanked: 817 times
I'd skip the power flush.
If you're going to do some drain and fills soon (good idea) then consider waiting until then to get the level more exact as it's probably fine how it is. Also fine to add 250 nL now as suggested.
Been thanked: 504 times
Post by cn90 »
Also,
I have done many simple drain/refill ATF in P80 and P2 cars...
The magic is during the last fill (after you reinstall the drain plug), about 3.3 ---> 3.5 qts of ATF will be fine.
Another trick is the long funnel (detail in forum) that fits inside the fill tube.
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I like to use a funnel with clear fill tank on top, a shut off valve, and a dust cap cover. I close the valve, measure the amount of refill ATF and then open the valve to fill. This seems easiest way to measure the partial ATF bottles when adding back.
Noie
Post by Noie »
I did another hot check today after the drive home. (Both checks shown in here are hot checks after the drive home). Today's read a little higher on the stick, still below the hot-mark hashes. Peculiar how inconsistent it is.
To reiterate, in July I performed 4 drain and fills over the course of a week. So the fluid is not 266k miles old, but it never was clear red either. However I purchased 24 more quarts of Toyota Type-IV ATF fluid to not only perform more drain and fills on this car, but also drain and fill my Dad's '04 V70R.
Thanks for all the recommendations and insight.
That’s fine. It’s inconsistent because fluid is pumped into the torque converter in liter(s) volume so the drain back amount is not always the same, unlike engine oil. That’s why the procedure calls for equilibrating the fluid locations with a drive cycle. If you are OCD you can get a consistent cold measurement but it’s easier to screw up
