Picked these up yday.
Cost me 240 euro to take this picture.
Partner driving Karla while the xc90 is down with a noisy ps pump. Have to travel this week so might have to give it to my Indy.
Fixed HVAC blower on SIL Mark 6 Golf. It bayonets in and out, no tools needed.
A bit of conFuseion on the fuse size, some resources say 25 amp, some say 45 amp. A 45 amp was installed. I didnβt have a 45A in my kit so I used a 30 amp
Used the T5 as a tow beast to finally get my VW T4 to my Indy for brake amd suspension work. I got the valve body in the trans but too busy to get her back in the road.
levalexi
- Year and Model: 2000 v70 xc se
- Has thanked: 9 times
- Been thanked: 6 times
I reglued my front R door panels and installed them. They're not perfect, and the passenger side could use a bit more glue, but they're better than the ones I had in before.
Unfortunately my driver's door lock stopped working all the time
it'll lock if it's up, but it won't unlock unless I pull the rod. I'll probably just deal with it until I go home again and pull the lock from the V70R.
I'm probably going to install some eBay silicone turbo hoses today after work. Hopefully everything goes well
I bought the blue radiator hose set too, but I'm going to return it,as I'm not touching the coolant until I get my Tacoma back next month.
- Has thanked: 2199 times
Re-gluing the door panels is a pain on this era of P80's. I have had to do this several times on mine and other's cars. First time I made the mistake of paying a 'professional' recommended upholsterer to do my driver's door panel on our R. Idiot did not use any load spreader on the material surface so now have a permanent indent on the top of the panel. Also there are gaps around the joins.
After that I have done it myself
Well done! Looks good.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I put new and nice eBay-used taillight lenses in my β94. Do NOT lose the tiny attachment nuts down in the abyss below - I used a lot of tools and two magnets to get it out.
- rolsen11
- Year and Model: 00 V70, 04 S60R
- Has thanked: 57 times
- Been thanked: 58 times
What glue do you use for this? Mine have failed a while ago and would like to get in there and do it at some point.levalexi wrote: 06 Apr 2026, 08:17 I reglued my front R door panels and installed them. They're not perfect, and the passenger side could use a bit more glue, but they're better than the ones I had in before.
Unfortunately my driver's door lock stopped working all the timeit'll lock if it's up, but it won't unlock unless I pull the rod. I'll probably just deal with it until I go home again and pull the lock from the V70R.
Hopefully everything goes wellI bought the blue radiator hose set too, but I'm going to return it,as I'm not touching the coolant until I get my Tacoma back next month.
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I had an intermittent long crank situation in my 98' S70 5-speed and decided to replace the fuel pump relay. The prices for the OEM relays have gone through the roof (FCP lists it for $209 now), so I decided to get a KAE one at $32. I have never heard of this manufacturer before, but they are made in Germany. Can't be that bad I reckon. The base looks a little different, but it snapped firmly into place.
This morning I ran some errands and started the car multiple times. It fired right up every time, so I am hoping this is resolved now.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
KAE are normally to be avoided due to poor lifetime/quality.
Heck, worth a shot based on the price of a blue box part! Please keep us updated as perhaps they have improved the quality of their part which would be great news! Thanks.
aboutcasual
- Year and Model: 1996 850
- Been thanked: 3 times
Replaced the manual shifter bushings with a 3d printed nylon set. To remove the gear knob, videos and forums will tell you to pull on it or hit it with a hammer. I managed to remove it cleanly by prying up the clips that hold it to the shaft. Would recommend this to anyone looking to do this.
