Need suggestion for front calipers - 2004 V70 2.5T
BobbyC777
Year and Model: V70 2.5T, 2004
Has thanked: 27 times
Been thanked: 7 times
Post by BobbyC777 »
I have a leaky bleeder valve. I looked at the original today and it was quite rusted. Unfortunately the new bleeder that I tried (genuine Volvo) leaked considerably more than the original. So I am resigned to buying a new caliper (or two). So far nothing has jumped out at me. FCP Euro has an Original Volvo caliper for about $305. Closer scrutiny shows it's a rebuilt. And there's a $100 core charge. And I read "Remanufactured units are often pressure tested." I wish it said "always pressure tested."
FCP Euro also sells Febi Bilstein aftermarket Chinese units for about $131.
IPD has some $65 rebuilt units with only a $27 core charge. I'm thinking if my bleeder seat is rusted that I may not get credit for the core.
And, of course, there's a bunch of stuff on Amazon.
I'd like to hear from those of you who have had good luck in buying calipers for the P2. I have the 286mm rotors. The Volvo part #'s are 8251315 (Left) and 8251317 (Right).
Thanks!
Bob
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
You might try lapping the seat of the bleeder valve using a new bleeder and valve lapping compound. You will not be able to get much rotary motion only on and off closed position. But it might be enough. I would work open and closed on the seat a bunch of times and then remove and renew the lapping compound. Repeat until you get a shiny seat?
Then use another new bleeder valve and retest for leak.
You don't have much to lose and may safe a lot of time and money.
BobbyC777
Post by BobbyC777 »
@volvolugnut - Thanks for the tip. I have looked for a proper lapping tool but have not found one. Maybe a bleeder screw with the threads ground down would work. Deformable soft washers that would compress is something else I am looking for.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
use a ball bearing, bigger than the bleeder hole, seat it over the hole and give it a sharp smack with a hammer, that should give it a sealing surface.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
I bought ATE for $138 before tax/shipping on partsgeek last fall. It is still a reman unit, I think, but they are all reman. And no core charge.
Edit: Well, it was new. But look at how the price went up, to: $202 before tax/shipping: https://www.partsgeek.com/32pjz13-volvo ... liper.html
Vova585
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
I think $200 is amazing price for a brand new oem component. Brakes would be the last area where I would try to cheap out. Thank you vtl
Been thanked: 504 times
Post by cn90 »
- Re bleeder screw...use ATE, much cheaper and same as Volvo.
I posted info in this forum.
- Try conical copper washer...
Post by cn90 »
I posted info on ATE bleeder screw in this thread below...
P2 brake bleed nipples, Brake Bleed Screw is ATE-390354
viewtopic.php?t=94805&start=10
The ATE bleeder dimension is as shown. If you can find a conical copper washer with O.D. ~ 8mm,
it should solve the problem. Conical washers are used in fuel lines etc. Or you can simply use a flat
washer and tighten it down, it will become a conical washer...
BobbyC777
Post by BobbyC777 »
@CN90 - this is a great bleeder thread - I appreciate the help!
Bob
Post by cn90 »
