RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
Tried one of those cheap combustion gas head gasket testers
The included fluid is so basic that it needed vinegar added to change color at all.
Validating the fluid with my breath and with a vinegar and baking soda reaction did not change color.
I'll try again with a different fluid
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Been thanked: 4065 times
abscate wrote: 19 Apr 2026, 02:53 Drove mine to Brooklyn and had pizza with daughter Friday night. 0400, up to park at EWR
Now 0300 Sunday in Ny, and I’m still in the air over the Pacific
I will seek Volvos in Singapore
Last day overseas! Can’t wait to see Karla waiting to take me home at the station
1999 Karla Kat s70
My friend foggy put the axle shaft back into the AT, took off the frozen viscous coupling, and added 2 liters ATF. I flew down to his house and drove it home
Just rolled over getting bagels!
xanthefin
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
jsrnsis wrote: 16 Apr 2026, 15:52
abscate wrote: 16 Apr 2026, 08:24 Definitely can be replaced, probably make them up with NiCopp and fittings.
I do not ***think *** these carry high pressure - I think they just shuttle fluid back from the low pressure side to the other as the rack turns. That might mean you could cut, flare, and then use PS hose with double oetiker clamps to repair - maybe?
Whatever they were, it sprayed out violently without the wheel being turned at all, I didn't even think of the "roll your own method", they do look just like brake lines. I have another rack that has one of those lines damaged too, maybe I'll try that first and have a good spare.
Today the mystery with the 2000 grows, yellow label etm came off, yellow label etm off a mystery engine went on, all I know it had a turbo. Car now starts and idles and drives but throws all these codes.
All started when he cut rear the O2 sensor off while the car was running because it was dragging.
Hi!
For me by looking at the story what happened.. you might have shorted power supply inside ECM which powers various sensors. You might want open it and take a look. I dont know is there fuse in between and in theory should have though.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
xanthefin wrote: 28 Apr 2026, 15:34
Hi!
So there's another power supply in the canbus ecm which would have such an issue? I'll take a look.
On another topic, is anyone going to be at the FCP show at Limerock Park this Sunday? I can't believe it's already going to be May.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
Is there a link to the Limerock event not involving Facebook or Instagram? I can’t visit those as Taylor Swift stalks me there for my T5 and bdub for his Miata…
5rivers
Year and Model: V70 1998 T5
Been thanked: 15 times
Post by 5rivers »
Bracket holding the serpentine belt tensioner and bolt holes to power steering pump, has a pulley on the bottom of it. I think the bottom bolt hole might be for a bolt to the alternator. Is the pulley on this bracket removeable? Then, if it is, what is the pulley called or have a part number?
I'm in the process of re-installing a few parts after finding the source of an oil spray that covered the alternator and a few other parts. This bracket was covered in hardened oil, but is a little cleaner now!
Appreciate your replies!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
abscate wrote: 29 Apr 2026, 02:42 Is there a link to the Limerock event not involving Facebook or Instagram? I can’t visit those as Taylor Swift stalks me there for my T5 and bdub for his Miata…
:lol: https://www.eventbrite.com/e/fcp-euro-s ... tdtcreator Maybe Swift will not stalk you at that link.
Also -> Amazon link
5rivers
Post by 5rivers »
Here is the pic of the bracket and pulley ('98 V70 T5):
5rivers
Has thanked: 2199 times
Been thanked: 1852 times
Check this drawing:
https://www.volvocarstorontoparts.ca/a/ ... 70064.html
The drawing shows the bolts has a plastic cover over it, although your version looks like the cover may be smaller.
