95 850T runaway RPMs when started
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
Has anyone ever had one run at 4000 rpm when started for no apparent reason? I reached in and manually held the throttle body shut to no avail. The only thing I could do was shut the key off at that point. I am reluctant to start it again because I don't think the turbo bearings will survive another 4000 RPM ignition kill.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
Has thanked: 311 times
Been thanked: 817 times
I think this could point to there IAC being stuck open? Or maybe the TPS is ruined and the ECU thinks the throttle is still open.
Easy to clean the IAC unless the hoses on it have turned to stone. Remove, fill with carb cleaner, shake to rotate the gate inside, dump out the carbon. Repeat.
TPS I always troubleshoot by swapping in another one, it's just an easy way to do it.
aeg
Year and Model: 97 850GLT
Has thanked: 2 times
Been thanked: 46 times
Post by aeg »
IACV stuck wide open, throttle vane bent, intake manifold came loose?
I don't think it could be TPS, it's not likely to get to 4000 RPM without tons of air coming in the intake.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
IAC, vac leak, etc. Something with air/fuel mix.
Also -> Amazon link
greg850r
Post by greg850r »
Thanks guys. I also doubt the IAC flows enough for this. Will swap in a TPS and look hard for an intake leak somewhere. It's time for PCV service on this one anyway so if I can't find anything I'll use a different intake when I R&R it.
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
