With hope of not being a burden I will start brief and give you as much as you might want if desired.
Note: I have video of fuel pressure gauge and engine sound during start, stumble and stall.
1998 V70 base model with 169k miles runs for a minute or two then stalls. No error codes.
- During end of winter a "low on steering fluid" sound started.
- Sound went away after adding fluid (ATF) and temperatures warmed.
- Two weeks back the car died after a 5 minute drive.
- Can restart if I let it sit for a couple of hours.
- Replaced relay immediately.
- Bought new fuel pump but haven't put it in.
- Has an unwavering 42 fuel pressure (42 when priming, 42 even while stalling and 42 immediately after.)
- Replaced Crank sensor this week.
- Has spark immediately after stalling (testing spark with $5 tester from Harbor Freight.)
Based on an old Matthew's thread I'm concerned about Fuel Damper under fuel rail. ( viewtopic.php?t=86966 ) As stated earlier I had a sound I though was low steering fluid. That just happens to reside in the same area as the fuel damper.
Local shop has some guys reputed for old Volvo work. They say that after what I've done they would just be throwing parts at it.
So that leaves me kinda desperate.
Also I just bought a ICarSoft Vol V2.0 scanner and hope to figure out data capture very shortly and see if that is any help.
Hoping for and looking forward to your advice.
V70 stalls when warm. Reason to suspect Fuel Pulse Damper Topic is solved
- dalel
- Year and Model: 1998 V70
- Has thanked: 29 times
- Been thanked: 7 times
Replaced the relay with one that someone gave me about 5 years back. IPD had more (original Volvo) in stock so I ordered one that I'll try and then stuff in the glove box.
Chieber
- Year and Model: 1998 v70
- Has thanked: 69 times
- Been thanked: 49 times
If you’d tried the bridging first and it didn’t work, then your old relay was probably still good to go.
I’d then retrace every connection you’ve touched before the problem started, before just throwing any parts at it.
Besides the relay, I just remembered that it’s a common problem for the antenna ring to fail too.
It’s the part that sits around your ignition key.
Otherwise, check ignition as well, a cracked distributor cap or bad coil could lead stalling/non start as well.
Vova posted this yesterday on how to check for sparks
1/2 a shitbox V70 1998 2.5 NA
- dalel
It just seems odd that I have no CEL or codes.
There is spark even immediately stalling. Which seems to point back to a fuel problem. But the pressure stays at 42psi so I feel like I'm going in circles there.
Jumping the relay makes me nervous but at this point I'm not sure I have a choice. Lol. Wish I had a car to go get some wire & stuff.
Already ordered a coil and MAF sensor. Yes, I'm throwing parts at it. With no error codes I'm just not sure where to go.
- Has thanked: 2199 times
My brother is having a similar issue with his 97 850 base. The car runs for about 15 minutes and then dies. All his checks have so far raised a few faults that have been addressed but the base issue still is there.
He has:
1) Replaced the Fuel pump relay and jumpered it and none have fixe the issue.
2) Replaced the injector relay with a tested good one, issue remains,
3) Replaced various rubber elbows that were rotten, those improved the rough running issue
4) Cleaned the MAF
5) Checked the fuel pressure and it holds pressure around 43 psi even with the ignition off.
6) Checked the resistances in the cam and crank sensors.
There is still a slim chance it is fuel related, but I think at this point it is unlikely.
It feels like it is an electrical issue where a component heats up and dies. But at the moment is is being elusive.
Hopefully you have better luck!
He has:
4) Cleaned the MAF
rrres
- Year and Model: 1999 v70XC
- Has thanked: 12 times
- Been thanked: 34 times
Hopefully, the MAF fixes the problem. It does sound like a problem with one of the sensors: stalling the engine once it goes into closed loop.dalel wrote: 17 May 2026, 08:58 Already ordered a coil and MAF sensor. Yes, I'm throwing parts at it. With no error codes I'm just not sure where to go.
It's blowby
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Cam position sensor?
Fuel pressure damper will not stall the engine if bad.
It's there to "damp" pulses from injectors to keep them quiet as possible.
Bad fuel pressure damper symptoms are loud injectors pulses.
Cam position sensor or bad ect(or it's wiring,since wiring often goes bad on these cars).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- dalel
While putting everything back together, this popped out from below the MAF. Isn't this the vacuum line to FPR? You can see a screw has been inserted into the hose to seal it.
This would seem rather relevant to the issue I'm having. But how on earth has this not been an issue for the six years I have had this car? And, what should it be plugged to?
... Dale
... Dale
- V70 fprVac.jpg (17.38 KiB) Viewed 989 times
- 506 Views
Last post by aharres
- 720 Views
Last post by Vovo_merz
- 16 Replies
- 8378 Views
Last post by valvolvo70
- 61 Replies
- 11730 Views
Last post by balzybenzy
- 3522 Views
Last post by 93ForMe
