I'm planning to replace that line that runs from the passenger side end of intake manifold, but not sure of the nipple diameter. Since I'm still driving the car I don't want to pull any of those lines due to concern about breakage until I'm ready with all the replacement parts.
I've got everything else—just not sure what I need to fit both ends of that small hose.
So ID size of hose that will fit there? 1/4"? 5/16"? Bigger, smaller?
Volvo 850 size of vacuum line nipple on end of intake manifold
I used blue silicone line on mine , I’ll check the diameter and report back. If I’ve got a spool I’ll send you some
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I used blue silicone tubing too... thick wall. Memory is that it was 6mm inner diameter.
- Has thanked: 2856 times
- Been thanked: 1332 times
3/16th inch or 4.8mm, see viewtopic.php?p=234116&hilit=hose+diameter#p234116
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
abscate: That would be great. I took a rough measurement for length. The run from pass side of intake manifold across to the throttle body area and down to the PTC looks like about 4 feet.
Over in London for the week. My bad
- 750 Views
Last post by JimBee
- 1302 Views
Last post by 98v70xc206
- 1541 Views
Last post by erikv11
- 1249 Views
Last post by mava
- 449 Views
