No....it goes to the upper half of air filter housing...there are two nipples for vacuum lines.
It's for vacuum operated flap for cold/hot air intake.
V70 stalls when warm. Reason to suspect Fuel Pulse Damper Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
If the MAF is the problem, shouldn't unplugging the MAF solve the problem? At least on Motronic 4.3 or 4.4 p80s this works because the computer uses default settings over what is actually measured by the MAF. If your V70 is ME7, it might not work that way.rrres wrote: 17 May 2026, 13:37Hopefully, the MAF fixes the problem. It does sound like a problem with one of the sensors: stalling the engine once it goes into closed loop.dalel wrote: 17 May 2026, 08:58 Already ordered a coil and MAF sensor. Yes, I'm throwing parts at it. With no error codes I'm just not sure where to go.
Also, have you tried replacing the fuel filter?
I could also imagine there being a bad connection. I have a 80ies Opel with a rare Bosch LE-Jetronic injection. For years the car ran fine after startup, but bogged really hard when warm. After years of not wantong to drive it for the bogging my kids fiddled with the connectors with the car running and turns out the MAF Sensors connection was just slightly corroded.
As soon as the car had warmed up, the computer was looking for actual data from the MAF and got erratic readings.
One more thing: Try replacing the coolant temperature sensor with a known good one. They can cause weird symptoms too
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Clemens
If the MAF is the problem, shouldn't temporarily unplugging the MAF solve the problem? At least on Motronic 4.3/4.4 p80s this works because the computer uses default settings over what is actually measured by the MAF.rrres wrote: 17 May 2026, 13:37Hopefully, the MAF fixes the problem. It does sound like a problem with one of the sensors: stalling the engine once it goes into closed loop.dalel wrote: 17 May 2026, 08:58 Already ordered a coil and MAF sensor. Yes, I'm throwing parts at it. With no error codes I'm just not sure where to go.
I could also imagine there being a bad connection. I have a 80ies Opel with a rare Bosch LE-Jetronic injection. For years the car ran fine after startup, but bogged really hard when warm. After years of not wanting to drive it for the bogging, my kids fiddled with the connectors while the car was running and as soon as he touchscreen the MAF connector it stalled. Turns out the MAF Sensors connection was just slightly corroded.
Been running fine ever since.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- dalel
- Year and Model: 1998 V70
- Has thanked: 29 times
- Been thanked: 7 times
Ordered a bunch of stuff but this may be simpler than I expect. My distributor cap, rotor, plug wires and plugs only have 10K on them but they are, I think, 5 years old. It certainly won't hurt to put some new ones in so they are ordered.
Still waiting on MAF and ignition coil. (they were out of Bosch coil so I ordered the MSD... somewhat leery here.)
Again, thank for everyone's tolerance as I stumble through this.
- dalel
Pretty sure I lost the cam. The attached picture shows the distributor cap with shavings taken out of the terminals. I want to say "Oh maybe this or that" but I'm pretty sure the cam has to be moving to take out pieces like that. Someone please tell me I'm wrong. ...Dale
- v70 dist cam.jpg (27.08 KiB) Viewed 1018 times
- Clemens
looks weird, for sure
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 312 times
- Been thanked: 818 times
Maybe just a poorly built aftermarket cap and/or rotor? Or somehow got installed wrong. Are you sure the metal mount underneath the rotor is in the proper orientation, on the end of the cam?
The rule on P80 cap and rotor is Bosch only and Bosch only.
- Has thanked: 1611 times
- Been thanked: 4074 times
Those look like standard high mileage ignition wear marks to me. Scrape them off with a sharp, stiff blade …a Boy Scout knife …isn’t life grand ? Girls are scouts now, and direction finding has been changed forever.
cap and rotor have only 10k on themabscate wrote: 21 May 2026, 13:02 Those look like standard high mileage ignition wear marks to me. Scrape them off with a sharp, stiff blade …a Boy Scout knife …isn’t life grand ? Girls are scouts now, and direction finding has been changed forever.
They look crappy. Spark has to jump through that detritus
- 509 Views
Last post by aharres
- 721 Views
Last post by Vovo_merz
- 16 Replies
- 8465 Views
Last post by valvolvo70
- 61 Replies
- 11907 Views
Last post by balzybenzy
- 3593 Views
Last post by 93ForMe
