P80 green board…no wait…water in the engine room , Sir! [Blocked cowl drain, left side] Topic is solved
Has thanked: 1609 times
Been thanked: 4064 times
With respect to the USS Squalus, Thresher, scorpion
I have water in the boat. Getting tons of water in Karla.
Sun roof drains running clear , check..
Door seals maybe?
Coolant level ok. Vacuumed two gallons out today.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Well that is hard to miss. Only in back foot well? Wet seats? Pranked by the Ford truck up the street?
Dry seats. I’ll check three sunroof drains.
No signs of water thtough door seals.
Stumped.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I,ve never had a functioning tailgate washer. does the waterhose to the rear run in the car or under the car. I don't think there is a separate reservoir, right?
1996 855 R,
2010 V70 D5,
Has thanked: 2197 times
Been thanked: 1851 times
Wet at front and back or just back (as per Volvolugnut)? Are the door drains clear? Are sure the left rear door is not sloshing around.
Door seals can leak between the seal and the door, but I have only had it on the front doors about the level of the door mirror.
How was the car parked when the water came in? Was it on an angle?
Have you checked the drains by the fuse box under the cover are clear?
Sunroof drains can fracture near the edge of the sunroof 'cassette' at the corners. But if you had those leaking it would give evidence of the leakage into the car through the headliner.
We got inundated with a real ocean rain storm while I was overseas. The Admiral told me it was coming down 4-6 inches per hour.
Current working hypothesis: Maybe the sunroof drains got overwhelmed and I’m just cleaning up the leftover
It stinks of coolant too , as,y residual heat exchanger leak left the foam with residue.
Coolant level rock steady in car.
Update
Came back from a week travel and rain.
Made extra effort to get sunroof closed and level. Car is dry inside.
6 inches of rain and water in the boat again. Looking at door seals I have something going on here, not right.
there is a piece of plastic trim out of place on the LHS rear door that might be re-directing water into the cabin
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Caulk sunroof shut, and rear doors. You only need the fronts.
What’s going on here?
