Smoke test - leaking injector
Vuym
Year and Model: 1997 S70
Has thanked: 18 times
Post by Vuym »
I did a smoke test on my 03 S60R because my boost was a bit inconsistent. Noticed that it all seems to becoming out of one injector - is this likely a failed o-ring? Any other suggestions?
Thanks!
Vuym
Post by Vuym »
Not the greatest video but hopefully shows what I’m trying to describe
IMG_0053.mov
(12.62 MiB) Downloaded 20 times
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
spray with brake cleaner whilst its idling.
but its leaking.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 94 times
Post by DavidE7 »
The P2 fuel injector o-rings used by Volvo are somewhat of a standard size and you should be able to get them at any auto parts store. Replace all 5 of the lower o-rings if one is bad. My 200,000 mile Volvos ran smoother after sending the injectors out for ultrasonic cleaning and balance testing. The injector shop also replaced all the o-rings, filters, and plastic caps and made them work and look like new. This YouTube video looks good for the injector removal procedure:
You don't need to remove the injectors from the fuel rail to replace the 5 o-rings sealing the injectors to the intake manifold.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Don't forget to grab some replacement pintle caps while you're in there. Good to get an o-ring and pintle cap kit. Easy job.
04s60 2.4
04xc70 2.5t
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
DavidE7 wrote: 26 May 2026, 20:39 My 200,000 mile Volvos ran smoother after sending the injectors out for ultrasonic cleaning and balance testing.
Where did you send your injectors?
ToyoToyo
Year and Model: C70 2002
Post by ToyoToyo »
Definitely replace all the lower o-rings while you're in there, they're cheap and it's not worth going back in just to do the others a few months later.
Vuym
Post by Vuym »
So o ring was definitely busted but not sure how to remove this transparent washer-like thing so that I can replace the rubber o ring. Is it just brute force with a flathead?
Vuym
Post by Vuym »
Nvm it stretches over it!
Has thanked: 1611 times
Been thanked: 4075 times
Brute force with a pick on the oring! Shot of silicone spray helps too
