Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Ironmarkbiltekniker wrote: 05 Jun 2026, 18:23 Built the teensy decoder. Connected it to the vehicle. Run software. When looking at the log it sends the LS can command. Cant find cem part # on ls can but it finds it on hs can. Shows it finding the part number. Puts vehicle into programming mode. Whole vehicle shuts down as expected. Starts the counter. Ends up going to 99 0 latency. Reboots vehicle then says cant find cem part number. Tried three different kinds of canbus modules like waveshare etc. checked wiring and diagram multiple times. Added in 12v converter to power externally didnt change anything. Adding and removing grounds didn't change anything.
Show us the log? What it says?
Also what car is it?
Ironmarkbiltekniker
Year and Model: 06 V50
Post by Ironmarkbiltekniker »
vtl wrote: 05 Jun 2026, 19:06
I have 5 P1 vehicles at the moment, ranging from 2005 to 2012. I may have to plug the unit in again to pull it up. I dont know if it gets saved automatically anywhere. BRB
vtl
Post by vtl »
Ironmarkbiltekniker wrote: 05 Jun 2026, 19:12 I have 5 P1 vehicles at the moment, ranging from 2005 to 2012. I may have to plug the unit in again to pull it up. I dont know if it gets saved automatically anywhere. BRB
It is not. Just copy-paste at the end and save somewhere.
You may also have a better luck with this version: https://github.com/cmolson/volvo-cem-cr ... e/one_pass
Ironmarkbiltekniker
vtl wrote: 05 Jun 2026, 19:23
I used the one pass version with same result. Here is log I just did.
teensylogcempindecoder06052026.txt
(12.21 KiB) Downloaded 49 times
vtl
Post by vtl »
Ironmarkbiltekniker wrote: 05 Jun 2026, 19:33 I used the one pass version with same result. Here is log I just did.
Code: Select all
Calculating bytes 0-3
1000 pins in 2011 ms, 497 pins/s, average response: 0 CEM clocks, histogram 0 to 0
[ 00 -- -- -- -- -- ] latency          0; std nan
[ 01 -- -- -- -- -- ] latency          0; std nan
[ 02 -- -- -- -- -- ] latency          0; std nan
[ 03 -- -- -- -- -- ] latency          0; std nan
[ 04 -- -- -- -- -- ] latency          0; std nan
[ 05 -- -- -- -- -- ] latency          0; std nan
[ 06 -- -- -- -- -- ] latency          0; std nan
[ 07 -- -- -- -- -- ] latency          0; std nan
[ 08 -- -- -- -- -- ] latency          0; std nan
Looks like logical pin 2 (hw pin 4) is not connected to CAN HS transceiver's receive line. Show a good picture of what you assembled?
Ironmarkbiltekniker
vtl wrote: 05 Jun 2026, 19:41
Code: Select all
Its quite the mess. I had verified each time, with a multimeter, when i soldered new can modules but you triggered my brain to check everything again. I guess i missed the jumper wire from pin 23 to 2. I hadnt been checking that and it was disconnected.
dwappertam
Year and Model: 2001 S60 P2
Has thanked: 3 times
Post by dwappertam »
Question about the 5v+ over 1k resistor, when done with writing complete, does de resister stays of remove it when done ?
trashrico8
Year and Model: 2005 V50 T5
Post by trashrico8 »
V70user wrote: 20 Apr 2026, 10:32
dwappertam wrote: 15 Apr 2026, 16:18 i know that i can use the VolvoSynchro V1.4 to get my cem aligned with my ECM
VolvoSynchro ver1.4 doesn't work. It can set 10 synchronization bytes, but doesn't give You the eleventh byte,
which together with 10 synchronization bytes allows to start the engine.
Without correct 11th byte value - engine will not start. It will crank but no run
That is what I mean :
I'm having the same problem on my V50 T5.
The ECM is completely fried.
I'm trying to reconfigure an ECM, but I'm stuck on the key learning process.
The ID48 is never recognized by the ECM despite using the ME9.0 Synchronization Utility software
Dudde
Year and Model: 2005 V70 and more
Has thanked: 16 times
Been thanked: 17 times
Post by Dudde »
trashrico8 wrote: 14 Jun 2026, 01:49
Just sync CEM to ECM if replacing ECM
trashrico8
Dudde wrote: 14 Jun 2026, 02:23
Either I wasn't awake or the translator reversed the letters.
But it's definitely CEM that I replaced. :lol: :lol:
