1999 s70 5 speed.
in early May, when we had weather in the 70s, I was driving around with windows down thinking "Man.. this car still really rides and drives nice!"
Famous last words.
I found myself approaching a light, I pulled car out of gear, came to a stop and before the light changed, I saw lights on my dash.
Car had stalled out. Started right back up.
Car continued to drive fine.. and then as I was approaching another light, I put in clutch , pulled it out gear and coasted. When I pulled the car out of gear, the RPMs dropped to 0.
It doesn't happen all the time. But it does happen. And when it does stall out it seems like the RPMs drop like a rock. Like 3000 RPMs, take car out of gear, RPMs drop suddenly. I have not tested how fast the RPMs drop when it stalls vs when it runs fine so I might be wrong about this.
Other symptoms seem to be occasional :
1) RPMs jump up and down 1000-1500 range in rapid change. But depressing pedal increase RPMs and makes it become stable
2) I have seen the idle drop to about 500 and then eventually move back up to 800ish but rarely. Note my car already has a XeMODeX ETM in it. I am second owner of car and it came to me with a XeMODeX serviced/updated ETM. Do the XeMODeX updated units go bad with regularity?
3) I have noticed that the pedal feels dead at times. This surprises me because when I notice this, I am not actively trying to depress pedal. There have been times where I am driving at a constant speed (around 25) when I feel like the pedal feels dead. It's odd because I never even noticed the pedal had a feeling at all. Just all of a sudden it feels like it's vanished. When this has happened it seems to "come back" withing a couple of seconds. When this happens, the engine RPMs do not change. It's just as if the pedal seems to vanish. I don't know how to properly describe it. Imagine if the pedal was designed to provide mild haptic feedback and then all of a sudden it doesn't.
What I have checked
I just started diagnosing this.
I was hoping there was some leak in the intake system or something similar. I started up the engine (it always starts fine) and then sprayed various components with starter fluid. No change in engine RPMs.
That's it.
The car worked all winter long just fine. No hiccups. It was only after I commented on how nice it was driving.
Can anyone suggest a debugging plan here? What to test and eliminate?
I also do not seem to have any active codes
-A
