I will tackle this job today and will add pictures. ‘
The YouTube videos, even the A1 video has been enshittofied with ads , so we will resist this by linking to this post so that Theis trend is arrested.
The TRQ video only has one ad as of 2026, that’s still ….
2006 XC70 Tailgate Strut recommend brands? Volvo 30674494 Stabilus 6308S1
- Has thanked: 1611 times
- Been thanked: 4072 times
Tools needed
10 mm Hex socket - two bolts on forward lower C-D trim along edge, one each side.
Torx T-25 4 bolts on lower tailgate trim
1 T25 above rear deck light for upper trailgate trim
2 T25 , one each side for upper C-D pillar side trim, to rear
thin screwdriver to remove safety clip
Hammer to pop off strut
Second person to hold/safety tailgate - you can prop it, but you dont want this thing falling on you - it will hurt and hurt you.
- B6CC2A3A-41B4-46E3-A29D-DBD61699977F_1_105_c.jpeg (148.71 KiB) Viewed 178 times
- 21978F9B-A4DB-40A2-BF3A-369444B7EFDE_1_105_c.jpeg (119.22 KiB) Viewed 178 times
- 8412E6F0-F167-4D19-B5DD-B4F209B63668_1_105_c.jpeg (111.03 KiB) Viewed 178 times
- AE309BE7-6CBA-44F0-AB68-0742BF210AEA_1_105_c.jpeg (129.89 KiB) Viewed 178 times
- 3E743459-978E-44C0-9990-9D736DD1E562_1_105_c.jpeg (99.22 KiB) Viewed 178 times
- 0869DE06-844B-48AD-9AC5-8C575BA0A6D5_1_105_c.jpeg (97.07 KiB) Viewed 178 times
- BF7446BD-058B-45E3-ACC1-8D594952D00C_1_105_c.jpeg (84.39 KiB) Viewed 178 times
- E95C827A-DDA8-410D-BC91-2851D2E9CC53_1_105_c.jpeg (106.03 KiB) Viewed 178 times
- 332BD095-FD37-45F8-A87F-389AAFD5CDCE_1_105_c.jpeg (69.3 KiB) Viewed 178 times
- 9342992B-CAC6-4535-99E3-5CA2E35DA821_1_105_c.jpeg (78.82 KiB) Viewed 178 times
- 64A63F7B-B7E6-40C9-A23F-F9BC64942DC7_1_105_c.jpeg (77.3 KiB) Viewed 178 times
- F853CF99-3BC1-4A97-AB48-D4C7354A140D_1_105_c.jpeg (64.88 KiB) Viewed 178 times
- F3FCF824-F5AA-4FCC-B3AD-D5A82E1A954C_1_105_c.jpeg (121.81 KiB) Viewed 178 times
Assembly order is
First in lower tailgate trim 4 T25
Next D pillar trim on each side - snaps only, no fasteners
Next upper tailgate trim - one T25 center, on top of light
Finally, two C-D pillar trim - 1 T25 rear, 1 Hex 10 mm socket front (m6 bolt)
Snap in two side cover pieces, left and right, no fasteners
- Has thanked: 2209 times
Typically for me the trim clips break for the side panels. They are those small black horseshoe clips that usually break. I keep a bag full of those I buy from a clip supplier in the UK as it is also used on P80's in the same area.
https://vehicleclips.co.uk/collections/ ... vo-9132876
They do several other clips for different models. They have always bee quick to supply and priced are way cheaper than Volvo. Mind you, if you only need 6/8 it might be a close cost if you never have to take those panels off again for removing the rear light clusters for example.
I have to say p2 plastic is a lot sturdier than p80
I did this whole job with zero plastic casualties
I left off a pic of the T25 on the C-D pillar trim, sorry
- Has thanked: 987 times
- Been thanked: 1078 times
My Southern Fried tailgate plastic panels (2001) are broken after once removed. I may try to super glue and put back in place, but I doubt it will happen. I have kept the pieces.
Try the abs MEK mix that Grantkat made up in the p80 forum, where the Kool kids hang out
- 13 Replies
- 1371 Views
- 10 Replies
- 2679 Views
- 14 Replies
- 2452 Views
Last post by bmdubya1198
- 86 Replies
- 7315 Views
- 14 Replies
- 2424 Views
Last post by erikv11
