Hi again guys-
My HU-613 radio crapped out a few months ago after a front-end fender bender, so I found another used one on Ebay but the seller says he has "NO CODES" included. I believe I read somewhere that my year, 2002, does not need any radio codes to enter to make another used radio work. Is this true?
Radio Code - 2002 V70 Base
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 158 times
- Been thanked: 6 times
- Has thanked: 2215 times
- Been thanked: 1853 times
Never seen a code needed for P2 radios. P80's yes not P2. Early P2's can have funny different stuff from the transition from P80 to P2. If it does somehow (99% unlikely) usually you can get it from Volvo from the Serial number on the unit. Not seen a code on a HU-613 unit.
Mr. Detail
Good to hear scot850.
Here is a screen shot of the back of the radio I just bought.
HU-613 used.pptx- (360.23 KiB) Downloaded 18 times
- Has thanked: 987 times
- Been thanked: 1078 times
I have never needed a code after I replaced car battery on my 2001 V70.
Mr. Detail
Yes, but I am replacing the radio, not the battery.
I understand, but I was thinking if a code was not required after battery replacement, then the break in electrical connection for a same design radio would not require codes because these radios never had a security code.
When I disconnect battery in my 2001 Mercedes, the radio must have the security code reentered.
Hopefully it all works out. Good Luck!
- 17 Replies
- 4936 Views
- 2171 Views
Last post by SonicAdventure
- 10 Replies
- 625 Views
- 11 Replies
- 10745 Views
Last post by JRL
- 811 Views
Last post by samus
