P80 C70 Hvac Drivers side only hot air, damper motor position, map of position counter, internal pictures
- Been thanked: 4068 times
It sounds like the blend door is sticking. Do the green LEDs on the ECC control unit flash when you first start the car?
CoupeC70
- Year and Model: C70 Coupe '01
- Has thanked: 10 times
- Been thanked: 2 times
No Red or Green LEDs blinking, everything looks normal.abscate wrote: 12 Jun 2026, 02:05 It sounds like the blend door is sticking. Do the green LEDs on the ECC control unit flash when you first start the car?
Will a defective blend door trigger a fault code ?
I could also order a used climate control unit to test it out. What makes me a bit suspicious about mine, though, is that the illumination on the driver-side temperature switch is really poor. Could this potentially be an indicator of a defective temperature switch hmm ?
That’s just a bulb.
The blend door motor plastic does get broken and that would cause your symptoms. There are no codes if the motor drives to where it thinks it should be even if it doesn’t move the blend door
- Has thanked: 2202 times
I thought 850 OBD2 was only for cars up to 1998 models. Not to be used on later cars.
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Works on my 2000 S70 turbo
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
CoupeC70
I pulled ou these error codes:
ECC has 3 DTC: 37 38 2F
ECC-312: Drivers side temp damper motor, no position change
ECC-411: Blower fan motor power unit, Faulty Signal / seized or drawing excess current [or blower fan obstruction, or power stage surge protector problem]
ECC-414: (inlet) Fan motor passenger comp (interior) temp sensor, Faulty Signal
Bingo!ECC-312: Drivers side temp damper motor, no position change
- 13 Replies
- 4279 Views
Last post by BEJinFbk
- 9 Replies
- 4115 Views
Last post by jvl
- 20 Replies
- 603 Views
Last post by cn90
- 991 Views
Last post by odaikorob
- 12 Replies
- 2104 Views
Last post by cbarbsnv70
