Help diagnosing bad engine sound *solved* Topic is solved
- seggs
- Year and Model: '09 S60, 04 XC70
- Been thanked: 4 times
vtl, the vehicle is FWD, so no angle gear. Can I access the port without axle removal?
2009 S60 2.5T FWD 155k
2008 S60 2.5T FWD 150k
2004 XC70, 220k(sold)
2005 XC90 2.5T AWD 173k(sold)
2003 S60 (sold)
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
I don't remember. Crawl under and check yourself? There's a small square window.seggs wrote: 17 Jun 2026, 14:56 vtl, the vehicle is FWD, so no angle gear. Can I access the port without axle removal?
- seggs
Yeah, I would if it were available to me. Just trying to be ready next time my daughter brings it home.
2003 S60 (sold)
- seggs
Finally was able to get under the car, and the good news is, on FWD cars, the bolts are easily accessible….an open gap right next to the axle.
The bad news is none were loose, so still on the hunt for the evasive, intermittent rattle I’ve been chasing.
2003 S60 (sold)
greffel
- Year and Model: 2003 S60
- Has thanked: 11 times
- Been thanked: 8 times
Did not find a link to the engine sound from you
My sound was really similar to rood knock
Off with the oil pan and check for worn bearings
Polestar 2 - All electric daily driver
S60 2.5T AWD with a little bit more power
vtl
High-pitched rattle is often a worn VVT hub or sticky VVT solenoid. Use stethoscope to locate the noise, and also record the video as already asked. Low-pitch rattle is something related to crankshaft.
