Hi all,
Have 2019 s60 Momentum and in need of the 2 front tires. The factory tires are Contis 235/45R18 98H. Have a quote for Bridgestone Prestige Turanza for $200 less than the Contis.The only difference is that they are 98W, rated for much higher top speed. I've heard that the higher speed rating the stiffer the side walls are.They are causing albeit sportier but at the same time tougher ride. Would it be correct assumption or for the regular driver which I am there should no noticeable difference? Thanks.
Correct tires... 2019 S60 235/45R18 98W
fields 100
- Year and Model: s 60 T-5 2013
- Has thanked: 2856 times
- Been thanked: 1332 times
I think that if you think you can notice the difference, then you are noticing a difference and it’s real.
Inflate (deflate) them to the low end of the range to try to improve the ride.
- 714 Views
Last post by mrscullini
- 1490 Views
Last post by kallekula
- 1466 Views
Last post by MoVolvos
- 3696 Views
Last post by Rattnalle
- 2016 Views
Last post by ljjones
