Fuel Quick connect accidental disconnect on highway
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
Cars with the quick connect fuel line fitting. Its been a few years since i changed the fuel filter and i do remember making sure the fitting was secure. However it appears the plastic insert (button) was worn and un-clipped itself while driving. With a small screwdriver i was able to replace just the plastic insert rather than the whole fitting. As a further pre-caution i used lock-wire so it never comes apart by accident.
Quick connect fuel line
quick connect.jpg (23.49 KiB) Viewed 167 times
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Cool solution. can you link to the replacement plastic insert supplier?
04s60 2.4
04xc70 2.5t
Has thanked: 2199 times
Been thanked: 1852 times
The problem is fine dirt gets under the compression tabs and makes them sticky. Often getting them off in the first place its the issue
My mechanic buddy uses a large pair of side cutters and cuts the outlet pipes off the ends of the fuel filter and then uses a lot of cleaner (WD-40/brake cleaner) to clean the tabs so and work the filter pipe remnants until it will release and then snap back fully on refitting.
Finally, he wraps the connections with tape (painters or the like) to keep dirt out of the connectors for next time.
Vova585
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
I am with Brody519. What was your source of plastic tab? You can buy rear fuel line for $80, front one is not available. Possibly tra splant from repair kit that fcp offers for about $35?
