RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
I realized that when I floor it, aside from the A/C compressor turning off lowering the temp noticably, I have a bit of exhaust smell in the cabin. Is this something like the fitting on the turbo gauge leaking under boost?
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Has thanked: 2199 times
Been thanked: 1852 times
Manovlov. Is your car a manual or automatic?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
RedBrickCollector wrote: 04 Jul 2026, 10:27 I realized that when I floor it, aside from the A/C compressor turning off lowering the temp noticably, I have a bit of exhaust smell in the cabin. Is this something like the fitting on the turbo gauge leaking under boost?
The boost gauge uses vacuum, no exhaust, so nothing to worry about. The AC compressor is supposed to shut off on wide open throttle though, so that's normal.
Check for any exhaust leaks, especially any flexible sections of pipe.
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
scot850 wrote: 04 Jul 2026, 19:10 Manovlov. Is your car a manual or automatic?
Hy neil, my car in manual non turbo.
Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
Just notice this while installing the strut brace. Wonder how long I’ve been riding with this.
Finished is installing the strut brace. Also pushed the knuckles of the struts inward, for more camber.
Tempted to save up for ipd sway bars, instead of saving up for a R or amg. The car just wont die. (Knock on wood)
1/2 a shitbox V70 1998 2.5 NA
Manovlov, as far as I can recall there is only a switch on the brake peddle for disengaging the cruise control. I think the other switch is for the setting and is from the stalk on the steering column. I was trying to think why perhaps a manual would have say a senor on the gas peddle if the automatic does not. Not having a manual I can't go out and check. Perhaps someone with a manual trans car wit working cruise control can confirm.
I like the picture of the V70R in laser blue! Just like ours but that one looks like better paint. We don't have the R wheels though. I've never been a fan of them.
Chieber
Post by Chieber »
I replaced the steering wheel a couple months back and removed it again to check why it isn’t straight, as compared to the old wheel.
Stripped the torx head from the airbag. Luckily I could hammer in a flathead and get it loose.
The tooth are not aligned the same. The new wheel is slightly offset. I guess that’s why it’s not straight.
Old wheel
New wheel
Before installing the new wheel back again, I replaced the airbag screws from the old wheel.
Time to get an alignment done again.
Chieber
Post by Chieber »
Not sure if this is useful at all, but it’s cheap enough to give it a try.
No harm trying! You can also add the front stiffening bars from a C70 that bolt to the front subframe bolts and also further back where the AWD has a crossmember under the prop-shaft to support the center bearing.
The also have a 2nd one that fits inside the front sub-frame, but some modification is needed to add that.
Has thanked: 1609 times
Been thanked: 4065 times
Another 5 HP gained! Even more if it was blue ! ( Grammar scholars…if it were blue for subjunctive?)
