S80 remtote fob sluggish opening doors
ola, tenho um S80 D3 de 2012, e estou com problemas no comando de chave, mesmo com uma bateria nova, o comando tem muita dificuldade em abrir portas, mesmo junto ao carro tenho que estar muitos segundos a pressionar comando de abertura para porta abrirem, podem ajudar com dicas ???
- Has thanked: 2854 times
- Been thanked: 1332 times
Welcome to MVS, morais. Please use English. Translated:
hi, I have a 2012 S80 D3, and I'm having problems in the key command, even with a new battery, the command has a lot of difficulty opening doors, even next to the car I have to be many seconds pressing opening command to open door, can help with tips ???
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 228 times
- Been thanked: 238 times
1. Any chance you have 2 key fobs? Is the issue reproducible with both fobs(is available)? If the issue is reproducible with both fobs- key fobs are not the issue. If you only have 1 fob- any chance your local parts stores have keyfob tester(it is a sensor that you put your keyfob next to and press any button. It will show you the signal strength which usually is indicative of battery health. In your case keyfob battery is new, so it will show you if the fob is capable of strong signal. ). This device can be alternative purchased on ebay for about $20 and can show you accurate frequency reading , etc.
2. When this issue started or you bought this car like that?
3. Any chance you are seeing fluid leak like picture in your rearview mirror?
- 1986 Views
Last post by EngineeringBloke
- 899 Views
Last post by MoVolvos
- 3325 Views
Last post by jtp
- 2421 Views
Last post by SuperHerman
- 9 Replies
- 1696 Views
