454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Sveedy wrote: 13 Jul 2026, 08:22 Very nice and very clean !
Is that some sort of euro rated trailer ball ? :)
Looks like it's forged as one piece. I see the curved type in the US, too, but multiple pieces so they look less... anatomical.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid
Post by 454cid »
The other day, I started the 850 for the first time in a few weeks. I've had the charger on the battery. I simply backed it away from the garage door, so I could have some room to work in the garage. I bought a used work bench (finally) and had to make room for it, and then get it set in place. It's already getting used, but just for sorting at the moment. I've renewed my efforts to clean/organize my garage and make it more usable.
Here's a question, I thought of while sorting last night. I ran across the factory Volvo wiper from my 99 S70, with the wing/air-foil. Has anyone successfully moved the wing to a new wiper, or found a rubber re-fill for the original frame? I'd like to put it on my 850.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Has thanked: 2203 times
Been thanked: 1852 times
Swap the whole arm over. 850 arms are not the greatest.
I have read of the swap being done, but have not done this myself. Only thing to watch is that it clears the hood when you open it.
454cid
Post by 454cid »
scot850 wrote: 16 Jul 2026, 15:58 Swap the whole arm over. 850 arms are not the greatest.
The wing is mounted to the blade frame. It doesn't involve the arm at all.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Been thanked: 4068 times
DennisCA wrote: 13 Jul 2026, 06:02 Wet sanded and polished the rear hatch that I repainted last year, got some excessive orange peel back when I painted it.
Oh and the window strip is not OEM. I removed it and after derusting and painting I filled it with black Sikaflex. Which I then put a glue on strip over.
While I was at it I also removed and repainted the wiper warm, it's a bit of a hack job but an improvement IMO.
Then I've used my extractor and washed all the carpets and seats.
I have to redo the upper and lower strips on my 1999 v70 Elizabeth.
Is there a thread on this ?
DennisCA
Has thanked: 6 times
Been thanked: 68 times
Post by DennisCA »
I didn't make a thread for that, that I can recall.
What I did was clean the old strip out and de-rust the area. Then I filled it with sikaflex. That alone will suffice:
I would have left it without a cover strip if the sikaflex hadn't developed bubbles. I believe I got water on them before it cured.
144ps
Year and Model: Volvo 855 2.4, 1997
Has thanked: 16 times
Been thanked: 13 times
Post by 144ps »
Today I took some time to wire up a new switch that isn't part of the standard equipment in german cars back then: the lock switch. Currently, if you want to lock the car while driving, you have to press the door latch. That's about to change—a nice touch, if you ask me.
To prepare, I had to remove the old pins. I cut the cables and the connector from a car I found at the junkyard.
Done. Tomorrow i will fit it in the car
Does anyone remember who wrote up the thread on clearing the Pcv block hole with stiff Tygon tubing to remove the junk with multiple applications? Asking for our fellow OR sufferer of p80 XC torture
No, but I would also appreciate it is anyone can find it. My brother has a 97 850 with PCV blockage issues.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
Battery clip arrived, so it's actually secure now for the first time since I got the car 😂
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
