The Symptom:The engine runs fine most of the time. However, when the car is stationary at idle, and I rev the engine up to around 2000 RPM, hold it there for a few seconds, and then release the throttle back down to idle, the engine will sometimes begin to stumble heavily and misfire.
When this happens, it drops down to running on only 3 or 4 cylinders and triggers a misfire code specifically for Cylinder 1.
What has already been checked and ruled out:Compression: Tested and confirmed good compression across the cylinders.
Spark Plugs: Brand new spark plugs installed.
Ignition Coils: Tested by swapping them around, and even installed one brand new coil.
The misfire code stays locked on Cylinder 1.Fuel Injectors: Brand new fuel injectors installed.
Swapping them does not move the code.
Wiring: The wiring harness to the ignition coils and injectors has been inspected and confirmed to be in good condition.
I dont know where to go from here, so if anybody can help me it would be nice
