1999 S70 AWD (FWD only) Sudden Rough running. [bad coil/plug and Dead original ETM at 100k/28 years] Topic is solved
THis one of the Great Mysteries of Life - why does a failing ETM cause a cylinder 3-4-5 no fire?
- Has thanked: 316 times
- Been thanked: 531 times
That is a really interesting detail about this one... that it specifically causes 3-5 to misfire but not 1-2.abscate wrote: 29 Jul 2026, 08:25 THis one of the Great Mysteries of Life - why does a failing ETM cause a cylinder 3-4-5 no fire?
I am guessing the ETM fails hard closed, and only the nearest runners (1-2
) get enough air to fire. But that should mean 3-4-5 run under vacuum and the brake booster vacuum also fails.
- 810 Views
Last post by huzzsaba
- 2109 Views
Last post by PeteB
- 13 Replies
- 8871 Views
- 12 Replies
- 2790 Views
Last post by greg850r
- 11 Replies
- 2364 Views
Last post by jerseykat1
