Long time member, first time poster..
Last fall, I wanted to do the heated seat mod in my 2008 XC90:
- I built the CEM Cracker and successfully used it to get the CEM pin.
- I swapped in both front heated seats and replaced the CCM for one with the seat heater buttons.
- I uploaded my CEM pin to Vdash, purchased the subscription and ran through the process to enable the heated seat option.
Voila, everything worked!
6 months later, I went to make a change to the seat temperature, and I am receiving "Write Error: 1215" in vdash.
After some research and opening a ticket with D5T5, they told me my pin is wrong.
That seems weird, but I decided to run the CEM Cracker again and verify the pin I had.
This time, the CEM Cracker eventually gave up and said the "pin is not cracked".
After quite a bit of searching, I can't find any more info on where to start to troubleshoot this. While I can send commands to the vehicle such as calibrating the CCM, reading and clearing codes, I am not able to do anything that requires the pin.
It almost seems like something is corrupted or messing with the bus.
Any ideas on how to chase this?
Programming Failures - 2008 XC90 - "Write Error: 1215" in vdash
benchtoplabs
- Year and Model: XC90, 2008
2008 XC90 3.2 FWD
1998 S70
1997 850 Wagon
1996 850 T5 (White)
1996 850 T5 (Blue)
1993 850
1987 740
2008 XC90 3.2 FWD
1998 S70
1997 850 Wagon
1996 850 T5 (White)
1996 850 T5 (Blue)
1993 850
1987 740
- Has thanked: 987 times
- Been thanked: 1075 times
Bump this post again in a couple days. Maybe someone will see that has an answer. I have no clue.
- Has thanked: 2854 times
- Been thanked: 1332 times
benchtoplabs, I edited the title/added the error. Your member->first post elapsed time might be the longest ever here at MVS. Sorry, I don't have an answer to your question.
benchtoplabs
Thanks for the replies!
I am heading in the direction of disconnecting the seats and the CCM module and testing again as those are the only changes I have introduced into the car. If that doesn't work, I will need to dive into CAN bus troubleshooting, but I was hoping someone on here had some similar experiences.
2008 XC90 3.2 FWD
1998 S70
1997 850 Wagon
1996 850 T5 (White)
1996 850 T5 (Blue)
1993 850
1987 740
2008 XC90 3.2 FWD
1998 S70
1997 850 Wagon
1996 850 T5 (White)
1996 850 T5 (Blue)
1993 850
1987 740
- Been thanked: 4063 times
I bumped this thread over to the P2 and then bumped it back as there as some good PIN crackers there.
Thats sounds like an HR non-compliant post.
Bumped to P2 for visibliity
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Seats sit on LIN-bus, not CAN. CCM is irrelevant, I'm not even sure if it talks that much to CAN. Your VDASH CEM reconfiguration either overwrote the PIN area somehow, or the bus is noisy, like some module didn't go to sleep mode.
Do you crack the pin in P3 or P2 mode?
benchtoplabs
I am not sure what you mean my P3/P2 mode. I used the CEM Cracker from Github for the cracking.
2008 XC90 3.2 FWD
1998 S70
1997 850 Wagon
1996 850 T5 (White)
1996 850 T5 (Blue)
1993 850
1987 740
2008 XC90 3.2 FWD
1998 S70
1997 850 Wagon
1996 850 T5 (White)
1996 850 T5 (Blue)
1993 850
1987 740
vtl
There are a few git branches in that repo, one is for P3, and there's even one for early P2 (brick-shaped CEM). Master branch is for P2 2005+.benchtoplabs wrote: 30 Jul 2026, 08:51 I am not sure what you mean my P3/P2 mode. I used the CEM Cracker from Github for the cracking.
What does the cracker say in console when it's cracking? Can you capture the output and stick it here?
benchtoplabs
I used the Master branch for P2 2005+.vtl wrote: 30 Jul 2026, 09:36There are a few git branches in that repo, one is for P3, and there's even one for early P2 (brick-shaped CEM). Master branch is for P2 2005+.benchtoplabs wrote: 30 Jul 2026, 08:51 I am not sure what you mean my P3/P2 mode. I used the CEM Cracker from Github for the cracking.
I have attached the original output from when I successfully cracked it a year ago. Are you looking for the most recent output where it failed? I don't think I captured that one, but I can do that again in the next couple days.
2008 XC90 3.2 FWD
1998 S70
1997 850 Wagon
1996 850 T5 (White)
1996 850 T5 (Blue)
1993 850
1987 740
2008 XC90 3.2 FWD
1998 S70
1997 850 Wagon
1996 850 T5 (White)
1996 850 T5 (Blue)
1993 850
1987 740
- 6567 Views
Last post by RobsS40
- 18084 Views
Last post by Nilsson
- 12 Replies
- 7112 Views
Last post by Martenk
- 11 Replies
- 19404 Views
Last post by jarkmackson
- 2099 Views
Last post by RobTheModd
