Washable cabin filter?
thafaz
Year and Model: 1998 V70
Post by thafaz »
Hello all,
Proud owner of a 1998 V70 2.4L auto, 197km. Just replaced the cabin filter; $30!!!
Is there a commercially available washable cabin filter? Or is this something I have to make myself?
Faz
thecheat
Year and Model: 1996 850 Turbo Wagon
Post by thecheat »
I bought a purolater from Pep Boys for $17, but i had to coerce it into fitting and making a good seal.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Not aware of a washable, but a non-carbon shouldn't run you more than about $12-15 and a carbon filter from a discounter should be about $22. Change every 15K mi.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
NoMechanic
Year and Model: 2004 S60 Turbo
Post by NoMechanic »
Ignorant on the subject... I have not replaced mine in about 45,000. I thought it just filtered the air. We are not smokers and live in a rural area - is this an important maintenance item?
E Showell
Post by E Showell »
Yep -- Pretty important. I am advised (but have no way of verifying) that failure to change this filter regularly can lead to failure of the a/c evaporator, which is a very costly repair if left to a professional and a very time consuming one if done DIY because, I believe, it involves removing the dashboard.
I believe the carbon one will filter pollen as well. If you are in a rural area and have allergy sufferers in the family, this might be an important consideration for considering the carbon filter.
'95 855 auto (sold)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
A washable one doesn't exist that I know of - but I bet you could create a washable one yourself - they have washable indoor & shop vac filters; just dissect one of them, cut out the old filter material, and fit it to your car's filter.
There are worse things you could forget about, but changing it out every now and then could make your nose (and maybe the blower motor) happy. 15,000 miles is a bit overkill - that's about 6 months for me, but I'd probably change it about once a year - especially after all the stupid pollen everywhere in the spring.
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
I actually have a different theory. I think failure to change the cabin air filter is actually beneficial in prolonging the life of the AC evaporator, while not so for the blower fan unit.
My AC is still going strong after almost 11 years and a lot of use, and I think that is in part due to the fact that the cabin filter was replaced only twice in the car. The more the filter is clogged, the better it filters = the less crap gets down into the AC. I do think that this can lead to the early death of the blower fan though. My fan is making strange noises from time to time and I am thinking it's on it's last legs. But as far as I know, my AC evap has no leaks. I tried recharging it one time because I thought I needed to, but it pretty much took no 134a.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
MarinerMan
Year and Model: 1999 V70 N/A
Has thanked: 6 times
Been thanked: 9 times
Post by MarinerMan »
thecheat wrote: 13 Sep 2010, 16:54 I bought a purolater from Pep Boys for $17, but i had to coerce it into fitting and making a good seal.
I know this is resurrecting a dead post, but do you have a part number for the purolator filter?
Has thanked: 1611 times
Been thanked: 4075 times
MarinerMan….if you get the Volvo or Mann filter from FCP you can send it in with your oil filter for credit every year.
F Sea P for you.
MarinerMan
Oh goodness that’s right. I have a whopper of a credit for them right now. I didn’t think about that. Thanks again Doc!
