V70 2004 I just lost drive.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
On the hiway at 70mph it started to feel funny, almost wobbly, I pulled over, no loose wheels.
Got back in and it will not move, nor shift into park, car keeps rolling. I'm on a slight hill. Engaged ebrake for now. I can hear a sort of ratcheting sound when engine is running, noise is located from ttans for sure.
AAA is on its way, 60 minute arrival.
Drat. I'm wondering if dropping the subframe caused a Trans shifter problem.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Following this... get home safe...
04s60 2.4
04xc70 2.5t
jonesg
Post by jonesg »
I suspect dropping the subframe for the steering rack might be the cause, routed the shift cable wrong by the steering shaft. Sounds like it's not quite engaging. I wonder if the cable popped off at the trans.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Might it be that one of the axles’ splines got pulled loose from differential?
jonesg
Post by jonesg »
Yes, considering I had the axle out for a week fixing the inner boot clamp, drivers side.... thats a real possibility, I hear a faint ratcheting sound in all gears, no sound in neutral or park but P will not engage. So yeh, thats a candidate. this was the real drive since reinstalling the CV shaft 3 days ago.
Tow came, I'm home, I pushed the car into the garage with the tractor, I'll get it on the rack and see.
jonesg
Post by jonesg »
duh.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Happens to us all...
viewtopic.php?t=53508
Also -> Amazon link
Has thanked: 2199 times
Been thanked: 1851 times
Yup, been there, done that!
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Can the MVS community determine the axle engagement so a mark can be made on the axles before install? The mark would ideally indicate the axle has been fully installed?
This happens too often and even when done correctly adds unease to axle work.
jonesg
Post by jonesg »
volvolugnut wrote: 12 Aug 2026, 18:44 Can the MVS community determine the axle engagement so a mark can be made on the axles before install? The mark would ideally indicate the axle has been fully installed?
You know its in right because there is zero gap between the steel cup and the trans seal.
Theres a 1 inch gap before the clip is engaged.
Hold the inboard cup straight with your left hand and use the outer end as a slide hammer to bang it home, if it won't go, disengage and rotate the shaft a few degrees and try again, I got it on the 3rd try.
