Has thanked: 2199 times
Been thanked: 1852 times
They basically look the same, and the new one even has the flat section for drilling and tapping a hole for the PCV hose. The connector is even threaded. No too terrible to drill and tap that, unless you live near a junkyard and have plenty of similar cars available.
Has thanked: 1609 times
Been thanked: 4065 times
Is this the 2000? Are NA 2000 non-coolant warmed PCV?
I might have one of these Bruno - in the air over Nova Scotia right now, landing at EWR
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
abscate wrote: 14 Aug 2026, 07:10 Is this the 2000? Are NA 2000 non-coolant warmed PCV?
Yes, it’s the 2000 base V70. Would be amazing if you had one!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hy,
Abscate, i've found the post :
viewtopic.php?p=604731&hilit=lock+cylin ... nt#p604731
On my P80, may i just replace the tumbler ?
Manov
manovlov wrote: 15 Aug 2026, 14:03 Hy,
Manov
It’s tough on the p80s, you have to drill three holes to release the tumbler, and new internal tumbler keys are not available
manovlov
Post by manovlov »
My friend who knows well P80 tels me that an option is to replace the half steering column. Does someone confirm the option ? I've read severals posts about the tumbler here, yesterday, and most of them say that to use an "used" part could either solve the issue for long time, or just "hold on" for few time.
Thanks a lot to all of you for your advices.
Manov
Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
Had a new alignment done and while the previous one was good, this one was more thorough!
He tried to get the maximum negative camber out of the knuckles.
Handles like a dream now.
Forgot to add these classics that were there.
1/2 a shitbox V70 1998 2.5 NA
rolsen11
Year and Model: 00 V70, 04 S60R
Has thanked: 57 times
Been thanked: 58 times
Post by rolsen11 »
Got the accessory belt tensioner pulley replaced. Wow that old bearing was smoked.
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 67 times
Post by DennisCA »
Fixed a rust hole
There are two layers here that got welded, an inner and outer layer, I forgot to drill the holes to plug weld the outer skin, I can probably do it now.
Going at it with a grinder. I'll keep refining it but filler is gonna what carries the day. Need to get some seam sealer and epoxy primer.
manovlov
Post by manovlov »
I replaced my starter switch, my fuel pressure regulator and both controls arms by LEMFORDER ones.
