‘92 245, lights all working except highbeams, but dash indicator light up as normal (?).. any input and/ or advice great
davidcschulte
- Year and Model: 1992 245
Have three old bricks ( 90,91,92), and have thus far a good run without the ubiquitous electrical gremlins ( or any for that matter.!). My workhorse daily 92 245 has no highbeams, low beams normal and all other lights.. strange thing is the dash indicator lights up as normal when I click the stalk..only no light..( swapped out both Bosch relays with ( untested) Bosch relays…any input or advice greatly appreciated…
- Has thanked: 987 times
- Been thanked: 1075 times
Check the high beam wires and connectors at the headlight. The wires can degrade from years and heat. If all wires look good consider the switch might be defective.
Test for high beam power at the relay.
I have had both problems with 240s.
davidcschulte
Hey thanks, I’ll do that asap…
- 165 Views
Last post by jreed
- 13 Replies
- 2800 Views
- 10 Replies
- 6257 Views
Last post by RickHaleParker
- 867 Views
Last post by MrAl
- 3486 Views
Last post by reeltapegone
