Use the "send periodically" command?dikidera wrote: 21 Aug 2026, 09:07 More features to come, like custom scripts to passively read the can bus so we dont have to query it, this improves sample rate a ton.
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
No more like custom scripting language that can incorporate the default params + intermixed with decoded data from CAN bus, such that you can read Engine Speed, Vehicle Speed and even pedal position from the CAN bus as it is streamed to get a better sample rate. Or when you want to read ram data but as you know, each software revision of an ECU has its internal ram usually shifted, so custom scripts allows targeting those specific software revisions, but from community members who are willing to share etc.
In my own benchmarks, send periodically even with fastest option resulted in slower sending of data than polling method.
- RickHaleParker
- Been thanked: 979 times
I like the concept real well. Maybe can retire VIDA at last but, why EUR market only?
Test bed: Samsung Galaxy Tab A.
Active
Past
Past
dikidera
Will be fixed soonish. It is the one thing I forgot to fix.RickHaleParker wrote: 22 Aug 2026, 20:02I like the concept real well. Maybe can retire VIDA at last but, why EUR market only?
dikidera
I have pushed out an update to address this, BUT due to how Google Play works and how the databases are stored there, the update will realistically download a large amount of data again. I will be looking into fixes as that is not sustainable.RickHaleParker wrote: 22 Aug 2026, 20:02I like the concept real well. Maybe can retire VIDA at last but, why EUR market only?
- RickHaleParker
Got the AME. Lots to explore.dikidera wrote: 25 Aug 2026, 09:34 I have pushed out an update to address this, BUT due to how Google Play works and how the databases are stored there, the update will realistically download a large amount of data again. I will be looking into fixes as that is not sustainable.
1. Initial update was 2.36GB.
2. Keep complaining about missing databases. A reboot took care of that.
3. Then go and download missing databases. I had to download the parts catalog again.
4. Anyway to move the ad banner to the top or bottom?
Active
Past
Past
gavik
- Year and Model: 2006 xc90
- Has thanked: 21 times
Is it possible to add Russian language?dikidera wrote: 23 Aug 2026, 01:31Will be fixed soonish. It is the one thing I forgot to fix.RickHaleParker wrote: 22 Aug 2026, 20:02I like the concept real well. Maybe can retire VIDA at last but, why EUR market only?
- RickHaleParker
Language packs can be huge. A option to add and delete Language packs might be the better way.
Active
Past
Past
MotorolaV3X
- Year and Model: 1999 S80
Hello dikidera, will it be possible to work with other adapters? sm2pro or dice
- RickHaleParker
MotorolaV3X wrote: 27 Aug 2026, 03:13 Hello dikidera, will it be possible to work with other adapters? sm2pro or dice
dikidera wrote: 21 Aug 2026, 09:07 Currently works with Mongoose JLR cable(with USB OTG adapter), but will likely support more stuff in the future.
Active
Past
Past
- 8994 Views
Last post by RickHaleParker
- 8825 Views
- 27 Replies
- 27658 Views
Last post by cn90
- 10 Replies
- 10231 Views
Last post by jonesg
- 5438 Views
