Auction car with 187,000
Minor evap code intermittent
Charged AC
No oil or coolant leaks
New battery Volvo
Good rubber 2022
Timing belt sticker at 170,000
Changed PS fluid to Dex6 ATF
Radio code 3541
Engine number xxxyyyy
Good news, held AC charge, then compressor Is hot cycling. Needs gap adjustment, gap 0.5 mm loose fit
Cracked and lubed all lug nuts , horribly tight. Patched front right sidewall tire
P0116 for bad ECT. FAN afterruns for 6 minutes , ordered part FCP Order Number:
R697260358
CHanged oil CASTROL SYN
Changed Coolant VOLVO
seep at radiator RHS
No oil leaks
Changed upper rad hose
My 1998 Turbo S70 GLT has the water pipe angling forward
If your water pipe connection angles forward to front of car, you need part 9470409 or equivalent
Tosh get a a 2 mile run around local roads at 30 mph to keep things moving. Not really a total get hot but oil is staying dry
11-2025 changed ECt, had to solder in new connector, thermostat/bolts replaced. P0116 code cleared
1998 S70 GLT “Tosh” 532035 417-26 BerylVolvo
Forum rules
- Has thanked: 1611 times
- Been thanked: 4072 times
Mileage note car was at 158k in 2014. 180k in 2025, so light use of 3000 miles per year
Mostly Volvo parts for replacements
Looks like timing Belt was done at 170k in 2014? So due 230k /2024
Had some funkiness in CDM , gauges dead on start up, the intermittent
Possible electrical switch issue?
Ac still blowing cold!
9-2026 drove two miles to Kerr things moving
- Has thanked: 2209 times
Again, pictures also have broken links.
