**Just to clear up. YES volvo keys can be cloned, if the locksmith knows how, theres a volvo trick
The aftermarket Silca key and the Aliexpress key are both plastic and noticibly lighter to the genuine volvo key. The Genuine volvo key can only be added via programming to the car, that is, it cannot be cloned (hence taking it apart). Programming can be expensive as in my case the dealership was unable to "add key" after downloading the software and follow up said they needed another 3 or more hours to "CEM update".
Cloning is easy when a locksmith knows how, thats the problem. The battery needs to be dis connected after every successful immobiliser log.
Volvo P2 key cloning vs programming
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- Has thanked: 2197 times
- Been thanked: 1850 times
So to clarify my understanding, the 2 aftermarket versions do not need the modification to the transponder key chip, it is only the OE Volvo that needs to be modified for this to work?
- RickHaleParker
- Been thanked: 977 times
If I get it correctly. The OEM chip needs replaced because it is read only. You cannot program a new ID code into it.scot850 wrote: 30 Aug 2026, 11:45 So to clarify my understanding, the 2 aftermarket versions do not need the modification to the transponder key chip, it is only the OE Volvo that needs to be modified for this to work?
Under what conditions you need to reprogram the OEM key not the control modules is unclear .
Active
Past
Past
Appreciate helping me understand this and the options guys!
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
ID48 chip was like two bucks for a dozen last time I looked. Exacerbating, of course, but replacing the chip is still two orders of magnitude cheaper than cutting a new key and mating it with car via dealer.RickHaleParker wrote: 30 Aug 2026, 16:14If I get it correctly. The OEM chip needs replaced because it is read only. You cannot program a new ID code into it.scot850 wrote: 30 Aug 2026, 11:45 So to clarify my understanding, the 2 aftermarket versions do not need the modification to the transponder key chip, it is only the OE Volvo that needs to be modified for this to work?
- RickHaleParker
True but still missing something. Do the OEM chips ever go bad?vtl wrote: 31 Aug 2026, 21:44 Exacerbating, of course, but replacing the chip is still two orders of magnitude cheaper than cutting a new key and mating it with car via dealer.
Active
Past
Past
vtl
Of course.RickHaleParker wrote: 31 Aug 2026, 22:32 True but still missing something. Do the OEM chips ever go bad?
- RickHaleParker
Oh yea ... ElectroMagnetic Pulse wiping them clean.
Active
Past
Past
- Been thanked: 4064 times
My new key addition at dealer was $80 in NYC for software and time
- 1347 Views
Last post by kingmatt336
- 1825 Views
- 1321 Views
Last post by paikas
- 867 Views
Last post by yagger
- 4725 Views
Last post by zenn
