BCM-0094 Communication between control units Communication problem with DEM
BCM-0109 Communication between control units Communication problem with SAS, internal fault
CEM-1A64 Communication with AOC control module signal missing
CEM-9C03 Antenna/light ring signal missing
MP2-0003 6 Disc CD changer internal fault
UEM-0004 Siren communication fault
UEM-0005 Sunroof communication fault
ECM-120D Air Mass - Signal too low
ECM-121B Mass Air Flow sensor flow too low
ECM-216D Long term fuel trim, bank 1 - signal too low
ECM-21E0 Long term fuel trim, bank 1, faulty signal
PDM-0025 Mirror motor signal missing
SAS-000F Steering wheel angle sensor internal fault
SAS0010 Steering wheel angle sensor internal fault
Additionally, my rear Nivomats are not working and I need to replace my AC condenser to fix my AC. My fuel gauge reads incorrectly (never goes above half and randomly drops to empty), and my headliner fell down last week. So needless to say I'm a bit overwhelmed here.
I have done loads of research but still unclear what could fix some of these or if one module is throwing some related codes. If anyone can shed some light and guide me.
I'm headed to the JY today for some odds and ends and will grab the fuel pump and sending unit to see if one/both of those will fix my fuel gauge reading.
I have VIDA but for some reason the only module I can view live data from is the ECM. I just reloaded the software again to ensure it was up to date but no change, so that's good, isnt it.
Seriously though, I appreciate any advice you may have. I DIY all I can but this car with its CAN-BUS system and need for dealer software relearn procedures and whatnot is ruining my enjoyment of the car.
