Need help w/ discontinued part (1997 850 GLT)
mrvigstuff
Year and Model: 1997 850 GLT
Has thanked: 3 times
Post by mrvigstuff »
Hey all,
So I recently started doing some of my own work on my 1997 850 GLT w/ about 226k miles.
While doing the PCV a couple weeks back, I noticed a cracked and old rubber elbow running from a hard pipe off what is *I think* the fuel pressure regulator to the intake manifold (apologies if I'm way off base, definitely still learning here). Here are pics of the elbow I'm talking about:
I believe the part in question is this discontinued "GCP Coupling Piece": https://usparts.volvocars.com/p/42819127/3531116.html
Also not available at IPD: https://www.ipdusa.com/products/18614/1 ... vo-3531116
I initially planned on just getting a length of silicone vacuum hose and cutting something to size, but it occurred to me that since this is either part of the fuel system or EVAP system, that the replacement might need to be rated for fuel. Has anybody on here replaced that elbow recently? If so, where did you find the replacement part? Or what kind of generic hose did you buy to replace it?
I've had a PO442 code (minor EVAP leak) for a while too...am I being too optimistic in hoping these are related? Seems like it's probably something off my charcoal canister, but guess I'm just hoping it's a more easily accessible fix :)
Has thanked: 2197 times
Been thanked: 1851 times
IPD have a kit with different hoses in it that may work:
https://www.ipdusa.com/products/5321/Va ... crumbs=983
aeg
Year and Model: 97 850GLT
Has thanked: 2 times
Been thanked: 46 times
Post by aeg »
Skandix lists 1332455 and 9125615 as substitutes, but your mileage may vary.
Only issue with Skandix is shipping cost to North America. They are brutal.
aeg
Post by aeg »
You can order those part numbers from whoever you want. You don't have to buy them from Skandix.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
On my 97 855 GLT, that hose is for providing intake manifold vacuum back to the fuel pressure regulator. In my opinion there is no reason the hose needs to be rated for fuel. I replaced the rubber hose with silicone about 10 years ago and it has been working well with no issues noted.
mrvigstuff
Right on, thanks for the help everybody. I live in Portland so I swung over over to the IPD warehouse yesterday to grab the vacuum elbow kit, but it doesn't seem like any of those are actually long enough or wide enough to fit the nipple or pipe. Gonna try a silicone tube, and just keep an eye on it. Thanks!
