Raddiator hoses 2002 V70XC
zeek
Year and Model:
Post by zeek »
I have 82,000 miles on my Volvo. How often should the radiator hoses be changed and how do you access the lower hose where it attaches to the radiator?
Thank you for your help.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Just feel them to see if they are soft...they should be pliable but not mushy. I would say you're probably good until your timing belt change (105K) anyway. To get at the lower one, you'll have to remove the air babble under there (up front, under the radiator), then you'll see where that lower hose attaches both to the radiator and back around to the engine.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
...How often should the radiator hoses be changed...
I just replaced my low hose after 14 years and 165k miles. I thought I found a crack at the neck, turns out my old eyes mistaken a rubbing mark as a crack. (Discovered after replaced it). These OEM hoses should last a long time if you keep them clean.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
zeek
Year and Model:
Post by zeek »
Hi Confused_Al.
Thank you very much for your help.
Zeek
