Turned key(engine) off removed from ignition blower , lights ra and radio stayed on.
Wiggled steering wheel back and forth(in locked position) radio, blower turned off, lights stayed on, eventually moving wires under steering column and wiggling things got everything to turn off.
Problem kept repeating, went under dash moved wires etc... thought I heard a click, can't confirm, but problem is gone for now.
Any thoughts?
850 Electrical Gremlin 1995, 150K, Non-Turbo
My first thought is the ignition switch itself. Common problem with them although its usually the reverse. Put the key and start but lights and radio won't work.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
damnyankee
- Year and Model:
Appreciate that however I removed the multi pin connector from the ignition and still had the problem. That too was my first thought, I'm more concerned that it may be the multi pin connector itself. Tracing those wires is like looking into a spaghetti bowl!
1995 850 GLT
- 36 Replies
- 8127 Views
- 2058 Views
Last post by alschnertz
- 621 Views
Last post by EamonnMR
- 714 Views
Last post by jonesg
- 13 Replies
- 5455 Views
Last post by oragex
