Hi
My check engine light went on last week. I connected my OBD2 scanner and got these two codes: P0101 and P2177, does anybode know what needs to be done to fix the problem^
Thanks,
XC90 Check Engine - OBD2 Code P0101, P2177
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Which year and engine?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
P0101, Volvo code ECM130A, is an intake air leakage, faulty signal.
Check the hoses and hose connectors between the Mass Air Flow meter and the throttle unit are not leaking nor defective. Check that the boost pressure sensor is correctly mounted and check for air leaks around the component. This DTC may be set by a blocked crankcase ventilation or PCV nipple or a damaged MAF sensor.
P2177, Volvo code ECM261A can also be an intake air leak. It may also be an exhaust system air leak, low fuel pressure, or a defective heated oxygen sensor.
Bill.
Bill.
Previously:
Previously:
- 2874 Views
Last post by precopster
- 3784 Views
Last post by RickHaleParker
- 1294 Views
Last post by CorgB
- 2593 Views
- 9 Replies
- 9245 Views
Last post by importCar
