850 Non-T 1994 intermitten "ticking"_Valves
jrinabq
Year and Model:
Post by jrinabq »
Are there speical tools required to adj valves. Eng B5254S. 85K miles Non turbo/Auto. Can I get info from you on whats needed to solve for mild intermitten valve train ticking :?: I'd like to attempt to solve myself if danger level isn't too great.
Thanks for your time.
Jeff in ABQ NM. Happy Holidays
VCA
Year and Model: 2008 S80 T6 AWD
Been thanked: 5 times
Post by VCA »
jrinabq wrote:Are there speical tools required to adj valves. Eng B5254S. 85K miles Non turbo/Auto. Can I get info from you on whats needed to solve for mild intermitten valve train ticking :?: I'd like to attempt to solve myself if danger level isn't too great.
I'm sure the rest of the gents on this forum will correct me if I'm wrong, but I believe all Volvo 5-cyl engines have hydraulic lifters and therefore do not require valve adjustment. Your tick is likely lifter tick caused by either low oil pressure or worn lifters. Does it go away if you rev the engine above 1300 rpm? If so, you likely need to install the oil pan o-ring kit (Volvo 30750783).
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
SnookWhaler
Year and Model:
Post by SnookWhaler »
Normal... What weight oil are you using?
As already posted. The lifters are hydralic, no adjustment necessary.
The "o-rings" (between the oil pan and block) can start to flatten on older cars and cause a light ticking at start up. Nothing to worry about in the short term.
1994 Volvo 850 sedan 165K
jrinabq
Year and Model:
Post by jrinabq »
Thanks gentlemen! To answer you questions.
Yes the ticking goes away post warm up and normal operating RPM ranges, but also intermttenly returns during these normal and warm running ranges. I've always used the standard 10-30wt quailty brands of oil. I'll plan to replace these O-rings per your suggestions. :wink: Please advise of other simptoms that would indicate a the more severe lifter(s) failure.
