1989 240 cranks but will not turn over
lukeblan
Year and Model:
Post by lukeblan »
i recently bought a 1989 240 with 200000 miles on it. I've driven it for less then a week and it has been towed twice already. The altanator and the battery have been replaced and it was running perfect, but today while i was driving the car turned off while i was excellerating. Now it cranks but will not start. im at a loss. Does anyone have any ideas??
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Is this the naturally aspirated engine or the turbo? If the former then there is an on-board diagnostic system fitted in the engine compartment which will show if any fault codes have been set.
To use this see: https://www.matthewsvolvosite.com/forums ... c&start=12
The method is the same for your car but some of the codes may be different. Read the codes and post back.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
GPZ900R
Year and Model:
Post by GPZ900R »
Mine has done this before - fuel pump fuse was faulty. Could also be poor contacts on the fuseboard.
Kmaniac in California USA
Year and Model:
Post by Kmaniac in California USA »
If you are not sure of the age or history of the TWO fuel pumps in your car, then search this forum for my posts on fuel pumps. This may be a contributing factor in your problem. Let me know if you have any questions.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
cucuracha
Year and Model:
Post by cucuracha »
check behind the timing belt cover and see if it is turning while you crank
