Man It's Cold Out** Heater Problem
Sidewinder
- Year and Model:
I am hearing this sound I think from the heater. It sounds a little like a bearing in the fan motor or something. Here is the weird part. It only does it when the car is accelerating. Once I level off and cruise no noise. If I turn off the whole HVAC system then no noise at all. Car runs great. Turn the heater back on in any position and the noise comes back. I am also getting an occasional antifreeze smell inside the car. At first I thought great heater core but if I turn the heater to REC then no more smell ever. I would think that if the HC was bad then there would be a smell no matter what. Could the smell be coming from a leaking water pump? Any suggestions would be great.
New to me. Black 95 850 Turbo
My First Volvo
A Wise Man once Told Me: Never argue with an idiot. Someone may walk by and not be able to tell you apart.
My First Volvo
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
It would be helpful to know what kind of noise, "that noise" is. Can you describe it a bit more/better?
Mike-Halewai
- Year and Model:
I have the exact same problem... if you're sure the noise is from the passenger side.. then it is 99% your blower motor.
I'm replacing mine this weekend, if you check out the thread here: https://www.matthewsvolvosite.com/forums ... =1&t=17743
Then you will see the thread that is going there, including pricing, symptoms and lot's of different advice, etc.
Mike.
94 850 Turbo Wagon.
94 850 Turbo Wagon.
Sidewinder
- Year and Model:
The noise sounds like a whirring like a bad bearing. Kind of like when you turn on a fan with a dry bearing, noise on startup but then clears up. Only problem here is that the noise is the same regardless of fan speed or vehicle speed. Seems to make the sound when accelerating. I was wondering if maybe there was some kind of vacuum check valve that might be leaking or something when the system changes from vacuum to boost on the turbo. It is weird because I get heat and the dual zones work fine. Just with it being in the teens and forecast to be 4 for the high this weekend I would hate to find myself without a heater.
My First Volvo
My First Volvo
MadeInJapan
I agree that it's most likely the blower motor.
Mike-Halewai
- Year and Model:
Well.. mine has been howling for about a week now. Acceleration and braking made a difference up until yesterday, now it howls from when it turns on until after the car is shut-off.
You should keep moving the heated air until that motor seizes, and that should last for at least a week or more. I have read on a few other sites that people have lived with that howling for up to 1 year or more.
Mike.
94 850 Turbo Wagon.
94 850 Turbo Wagon.
Sidewinder
- Year and Model:
Thanks. Sounds like I will start with a blower motor. At least it sounds like I have a little time. I can look around the junk yards for a replacement.
My First Volvo
My First Volvo
Mike-Halewai
- Year and Model:
If you go with a used unit be sure to add a little di-electric lubricant if you can. Shouldn't hurt, and maybe give you a little extra life, especially in the cold, which also brings with it a dry factor which certainly doesn't help a bearing stay lubricated...
Mike.
94 850 Turbo Wagon.
94 850 Turbo Wagon.
SnookWhaler
- Year and Model:
Bad idea... Better to try and repair/lube your existing motor or just get a "new motor" and replace "just the motor". Instead of the entire assembly.Sidewinder wrote:Thanks. Sounds like I will start with a blower motor. At least it sounds like I have a little time. I can look around the junk yards for a replacement.
You can remove the entire "fan motor assembly" from the car, remove the "fan motor and fan" from the assembly, remove the "fan" from the motor shaft, install the existing fan on a new motor and install the "fan motor and fan" back into the existing assembly.
1994 Volvo 850 sedan 165K
Mike-Halewai
- Year and Model:
I'm not certain as to why it would be "a bad idea" to replace the entire assembly with a used one? It might be good for you to explain this thought a bit more in depth?SnookWhaler wrote:Bad idea... Better to try and repair/lube your existing motor or just get a "new motor" and replace "just the motor". Instead of the entire assembly.Sidewinder wrote:Thanks. Sounds like I will start with a blower motor. At least it sounds like I have a little time. I can look around the junk yards for a replacement.
I just replace my entire assembly this afternoon and with absolutely no problem at all. The used unit sounds even quieter than mine did before the bearing went south.
I did however make sure to spray some silicone based lubricant as recommended by billofdurham .. thus far... -9 Celsius.. no problems. The squirrel box is exactly the same as my last blower motor even though the manufacturing dates were different.
Mike.
94 850 Turbo Wagon.
94 850 Turbo Wagon.
- 344 Views
Last post by Olegs855R
- 3118 Views
Last post by nucci480
- 7802 Views
Last post by oragex
- 2326 Views
Last post by cn90
- 1476 Views
Last post by Sommerfeldt
