I've been experiencing intermittent stalling problems, and reading the massive thread on the subject: https://www.matthewsvolvosite.com/forums ... php?t=3484 trying to get it resolved.
One of the things I want to try is replacing the fuel pump relay. Mine still works, but I suspect it of failing intermittently. My problem is, the replacement part I bought doesn't work at all. I must have the wrong part, but I'm not sure what the right part is. The tale is a bit convoluted.
Here's what I know:
- The relay I'm replacing is labeled 103, and is in the fuse box on the driver's side, under the cover. The part has a yellow cover, and has 5 connectors because it contains 2 relays. The part number is 9434013. This is different to the red #103 relay that's often described as the correct part for a 1995 850. The red part has only 4 connectors. Apparently the red relay is for manual trans, and the yellow relay is for auto trans?
- You can't find a new 9434013 part for sale anywhere. I called 2 Volvo parts departments, and they both say that part has been superceded by 9441029. The 9441029 is offered by several online retailers, and is consistently listed as the fuel pump relay for 850 non-turbo automatics.
- I bought one from Autohaus AZ. Its a KAE part. The part appears identical externally, and has the same labels for the connectors. It seats properly as well. However, after engaging immediately after turning the key, it disengages after a second, and the car stalls. I got a replacement part, and the same thing happened, so it was not a faulty part. The replacement part contains 2 coil relays, but the original is all solid state.
Before I go and get another part directly from Volvo, I thought I'd post to see if anyone has any experience with this. Anyone else replace the fuel pump relay on a 95 non-turbo 850 with auto trans? If so, what part did you use?
Correct fuel pump relay for 95 850 non-turbo automatic
confused_al
- Year and Model: 1996 TLA wagon
The correct part# is 9434225. This is the new substitute with 4 prongs for the part# VADIS calls for 95 n/a.
I bought one from myswedishparts.com (dealer) for $38 and works like what suppose to.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
confused_al
Why do you think its wrong? The 5th prong is just an extra ground connection.I figured 9434225 was wrong since it had 4 prongs
Yes, My 95 n/a is auto.
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- Year and Model: Many Volvos
- Been thanked: 76 times
All of mine, automatic or stick, turbo or N/A are interchangeable. Some of my cars have the red 9434225 relay and others have the green 9434138 relay but I can swap them back and forth between cars with no problem at all. I have never seen a yellow fuel pump relay with 5 pins. Post a picture of what you have.
confused_al
Only on 95's?...I have never seen a yellow fuel pump relay with 5 pins...
- IMG_0340.JPG (28.29 KiB) Viewed 5957 times
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Thanks guys. Sounds like 9434225 is probably the right part to try.
Yup, that's the same as my part:
When I called the local Volvo parts dept and gave them my model/year/etc, they first gave me 9434225. But when I told them my relay has 5 pins and gave them my part # (9434013) they said it had been superceded by 9441029.
If the extra pin is just a ground, and 9434225 works for others, then the 9441029 info must just be an error.
Here's the replacement part I bought (that doesn't work): http://www.eeuroparts.com/Main/PartDeta ... id=9441029.
The info on this site is consistent with what Volvo told me.
confused_al
Wow, $80????
Once I fix mine by using "Ozark Lee Method", would sell for $40. Any taker?
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
That is fascinating. I wonder what pin 87B goes to? I have a 94 and a couple of '96s. None of them have the 5th pin. I will study the Polish schematics tonight to try to figure it out.
- 740 Views
Last post by Ozark Lee
- 2824 Views
Last post by bluesmoke
- 11 Replies
- 2769 Views
- 5127 Views
Last post by wizechatmgr
- 3200 Views
Last post by cajunxchange
