Knock knock, from the top of the struts
This topic is in the MVS Volvo Repair Database » Knocking Volvo 850 Struts
sony2000
Year and Model:
Post by sony2000 »
I've recently changed all the ball joint connections with the exception of the inner tie rods. At 80,000 miles and in frigid weather, the top of the struts knock at every bump in the road. The shocks are acceptable but are a bit long in the tooth, ie. original. Top plates, bushings etc. should be worn out, but at this point, could it only make sense to to change the shocks at the same time, or is there a fix from the top side?
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
There is a 99% chance that the spring seats are broken. The bad news is that the springs need to be compressed to change them so, in terms of labor, it is the same as changing the struts. For the spring seats replace them with OEM XC90 spring seats which fit fine but they are much beefier. They only cost a few dollars more than the standard 850 seats.
sony2000
Year and Model:
Post by sony2000 »
Thanks Ozark. I get the impression the strut can stay attached to the hub for the operation. In my group of "the boys", I'm charged about $45/hr, off peak times, in a independent garage. The older owner and I, like to diagnose together, the new technology in cars.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
timmyc
Year and Model: 93' 854 GLT
Post by timmyc »
Ozark Lee knows his stuff. I need to do the same thing. If you look in between the top bushing and the strut tower itself, you should be able to see some lateral movement if you rock the car. Good luck!
93' 854 GLT 212k
97' 854 GLT 115k
97' 328i 252k
rgrady
Year and Model:
Post by rgrady »
Ozark Lee wrote: For the spring seats replace them with OEM XC90 spring seats which fit fine but they are much beefier. They only cost a few dollars more than the standard 850 seats.
Pay particular attention to this recomendation. I installed FCP spring seats, 2 months later replaced them with these because the others failed. Getting real good at removing/replacing struts now.
'95 850 Turbo
03 Cummins Turbo Diesel
02 Paint 1 horse power hay burner
07 Paint 1 horse power hay Burner
08 Palomino 1 horse power hay burner
holler1
Year and Model:
Post by holler1 »
rgrady,
How did you diagnose the spring seat failure? I replaced my struts, spring seats, strut mounts etc last summer with FCP Groton OEM parts (V70 not XC90). Now I have a "pop" when steering near to lock driving slowly (both sides). It's hard to tell where the noise is coming from. My first thought was inner tie rods but they are fine. Then I thought it was the steering rack but the steering seems very smooth with no noise at all with the wheels jacked up. I tried steering from lock to lock today sitting still with the front wheels on snow, and heard the sound once from the right side, but it would not repeat. It seems to need the forward motion to trigger it and I'm wondering if it could be something in the suspension.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
Post by Ozark Lee »
It could be as simple as greasing the plastic bump stops on the control arm.
holler1
Year and Model:
Post by holler1 »
Ozark,
I'm trying to envision what you mean. Here is the control arm photo from FCP website. I can't see where the bump stop is or how it works. Can you add a little to your comment?
volvo v70 awd control arm.JPG (26.55 KiB) Viewed 6037 times
When the car was sitting today, I was turning the wheel from lock to lock, and the sudden "pop" occurred when it was near but not at lock on the right side. However, I don't see how it would hit the bump stop if it isn't moving up and down. I'll take a look tomorrow at the actual control arm on the car. It's below zero here but is supposed to warm into the 20s tomorrow.
rgrady
Year and Model:
Post by rgrady »
Mine was more of a creaking noise from the right side. When I took the spring seat off it had collapsed and was rubbing on the strut mount. It had actually cut a groove into the spring seat from rubbing.
I would try Ozarks suggestion of greasing the stops first. If that does not solve it get an oil can with a long spout and shoot some oil on top of the spring seat. When I did this on mine the creaking stopped so I ordered the "Genuine Volvo" XC90 seats from Volvo of Richardson in Dallas. Creaking gone.
'95 850 Turbo
Post by Ozark Lee »
Holler1,
On the second picture note the white plastic piece on the side of the control arm. Smear a gob of grease on that part and see if the problem goes away.
