V70 1998 Died On Road
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
This past weekend, the 5 speed non-turbo V70 just stopped running at a traffic light. Had been humming along fine. Brake for light, car stops and dies. Will not restart. Towed away.
Following morning, it started right up. The battery was past its useful life and has since been replaced. Charging system was checked and is fine.
Any idea why the car would just die like this?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
You need to get your trouble codes read at an auto parts store and write them down- then post them up here. Hundreds of reasons why your car might die like it did. The codes will help us pin point where the actual problem is.
dcovey
Year and Model: 1998 S70 GLT5
Post by dcovey »
MAF?
When it stalls next time and won't start, unplug the MAF and if it starts after that you've got a bad MAF.
Or you could go the "easy" way and pull the codes. :wink:
1998 S70 GLT5
16T, White Injectors, .040 Overbore, Masterlube pre-oiler, Teflon intake manifold spacer, VMS Performance ECU, VMS rods, ARP Studs, MSD Ignition, Reverse IC piping, completely new from the firewall forward.
E Showell
Post by E Showell »
And MAF would be?
'95 855 auto (sold)
E Showell
Post by E Showell »
Gas mileage also appear to be about 75% of normal. Could it simply be a tankful of bad gas?
'95 855 auto (sold)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Old battery or corroded/bad/loose battery cables.
Also -> Amazon link
E Showell
Post by E Showell »
Battery replaced with new. No recurrence of problem since then.
'95 855 auto (sold)
MadeInJapan
E Showell wrote:And MAF would be?
This: http://volvospeed.com/Repair/maf_secure.php
It's right past your air filter box and before the accordion hose.
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
Next time it quits, check for fuel pressure at the shrader valve at the end of the fuel rail. If there's not a good squirt of fuel (use caution - catch spray in rag), then it's a fuel delivery problem: flaky fuel pump, or fuel pump relay.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
