Monroe Sensa-Trac Struts
Well, I gave my mechanic the price RockAuto.com lists for their KYB shocks/struts and he can't come close. Looks like he's figuring 2 hours for the front, 1 for the back, labor. I think I'll approach a local shop about installing the equipment I buy from RockAuto. I have a question about the mounts. How do I know if they need replacing or not? Any thoughts?
Wildman
2001 S60 2.4T @110K Miles
You may have already checked, but in my experience with Rockauto the prices are very cheap, then when you get to the checkout screen the shipping will be absolutely ridiculous. So much in fact, that on most items I have priced their deal is no longer a deal. Good luck
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
At 110K miles, you're best bet it to go ahead and replace the spring seats- don't skimp here...the cheap stuff just wears out quickly- then you're in to replace them again ($$), even though your struts are still good. I personally am recommending the XC90 spring seats or the heavy duty ones from www.ipdusa.com for all of our FWD/AWD Volvo's.
Is there anything else besides what I have seen called "strut mounts" that go between the top of the strut and the hole on top of the fender well? Thanks in advance.MadeInJapan wrote:... go ahead and replace the spring seats ...
Wildman
MadeInJapan
On our cars, the strut mount looks like this:
These do wear out too but not as much...this is the piece that buts up against the very top of the strut tower and you actually screw the bolts on to which keeps the struts in place. Just check them and if they look gnarly or don't turn well, change them too.
I suppose you know that the spring seats are these:
and these are the pieces that will almost always be bad when you change out your struts.
On the rear there are only shock mounts (well there are "bump stops" that can fall down in the coil and rumble around...if this happens, there is a cheap plastic clip that you can buy that will restore their functioning).
You are right, fcpgroton has a great package deal for all 4 wheels. No shipping charge. If I buy I'll try your discount code. Now I just have to find a shop willing to do labor only.MadeInJapan wrote: You might check out prices at http://www.fcpgroton.com (10% discount with "frosty" at checkout)
Wildman
MadeInJapan
Discount code has changed for this month....I read it somewhere but forgot to write it down- If I can think of it, or come across it again, I'll post back.
Found a very good price on a four wheel strut and shocks kit from FCPGroton.com. It is OEM equipment (Sachs). It absorbs the shock of pavement cracks and carrot-sized bumps much better now. However, the ride on this car is very sports car like.
I had my local shop put the struts on, but there was some knocking/ rattling in the front. I took it back and they fixed that, but I hear a straining from the upper strut mount when I turn the wheel. I guess I'll have to take it to a Volvo specialist - so much for the money saving route.
Wildman
Funny,otis44 wrote:You may have already checked, but in my experience with Rockauto the prices are very cheap, then when you get to the checkout screen the shipping will be absolutely ridiculous. So much in fact, that on most items I have priced their deal is no longer a deal. Good luck
RockAuto shipping has always been quite reasonable for me...to California.
- 1076 Views
Last post by FCPEURO
- 673 Views
- 1093 Views
Last post by MoVolvos
- 2071 Views
Last post by bmdubya1198
- 15 Replies
- 2818 Views
Last post by GreenMagicMan
