sunroof rattle
This topic is in the MVS Volvo Repair Database » S60 Sunroof Rattle Fixes
Volvo s60 24t
Year and Model:
Post by Volvo s60 24t »
Sunroof on my 02 volvo s60 2.4t rattles when i hit bumps. I checked the screws that mount it to the track and they are nice and tight. It only seems to have the slightest movement when its closed, when I open it and try to move it around a little its very tight - i get no movement.
Anyone know what I can do to fix this?
bshinn
Year and Model: 01 V70 2.4 T5
Post by bshinn »
Rails are worn, learn to live with it or plan on spending BIG coin to replace the whole unit. Very common on these cars.
trigon82
Year and Model:
Post by trigon82 »
sometimes a rear metal bar which is mounted with adhesive to a glass sunroof can come off and you cant see it, just put your hand between glass and cover and see it if its sitting at the top of a cover.
bshinn
Post by bshinn »
If it's really bad, then that's probably it. I pulled the front & rear rails off about a week after I bought the car in November, cleaned everything & tried to epoxy it back on. Fell off 3 days ago :x . I'm going to leave it off, but I expect it to shatter one of these days when I hit a pothole.
Pull the plastic accordian trim off, remove the 4 t25 torx screws, & take the panel out. The steel support might be stuck to the glass, & just loose.
NE1 know if an 850 glass will interchange?
gobies
Year and Model: 05 XC90 2.5,07 V50T5
Post by gobies »
There's also a metal strip glued to the front bottom edge of the sunroof-glass frame. It pushes the front edge of the sunroof up when the sunroof is closed. Volvo's eco-friendly glue loses its grip. The strip has a slight bend so when glued to the sunroof frame, it's under tension. The glue fails gradually, letting the strip flap against the sunroof frame. I pushed on the loose end (passenger side) of mine (2001 V70) and the strip popped off completely, with all the hardened glue attached. A little epoxy and some spring clamps reattached it. I also had a smaller rear strip come loose (discovered it on top of the shade); but I can't figure out where it should attach. These things don't show up on the Volvo parts diagrams.
bshinn
Post by bshinn »
Pull the glass, the location was pretty obvious on mine.
