I know I've been dragging this out but I'm still stumped.
The windows, mirrors, and sunroof still don't work. I put power directly to all the window motors to make sure I got them all up to keep the snow out, so I know all of the window motors work. I've checked and re-checked the circuit breaker and that is also fine. I have no clue what could be going on. One other symptom I've noticed is that none of the door switches (all four doors) light up anymore, which leads me to believe that there isn't power making it all the way back. Would a faulty master switch cause all doors to not work? The power locks still function, which only adds to my confusion. Thanks in advance for any opinions.
Still having the V70 window issue
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
It does sound like a "no power" deal.
The LEDs in the switch are connected to window power.
Have you checked the voltage on the output side of the
breaker while it's in circuit and you're trying to move a window?
Update:
I replaced the master switch after finding that I have a ground to short somewhere, so I assumed it was the switch. However, this did nothing. Has anyone had problems such as this, or seen a ground to short which causes the circuit breaker to trip constantly from startup?
'98 V70
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
A stuck or bound motor would do that as well.
Yeah it does trip with the master switch removed. I've applied power to all the windows separately MIJ, so I don't believe they are stuck. I tried running through all the wiring diagrams with an electrical engineer and we couldn't find anything when testing with a multimeter except that it was shorting to ground. Really thought it was going to be that master switch. I tried pulling the sunroof switch and the mirror switch but still no luck.
'98 V70
Everything failed at once. All 4 windows, power mirrors, sunroof. I've cleaned the switches and such, it's looking like i'm going to have to start chasing individual wires to find where it's shorting to ground. Unless anyone has any other suggestions?
'98 V70
- Year and Model: Many Volvos
- Been thanked: 76 times
Here is a link to the schematics. The site is very, very, very slow:
http://pliki.mojevolvo.pl/volvotechinfo ... n_3_39.pdf
They are somewhat incomplete.
Electrical wiring problems are a bear to find but very easy to fix once you find the problem.
Thanks for the diagrams, I have a few different ones, they're just not the easiest to follow. I'm a mechanical engineering technology student and was working on going through them with and Electrical Engineer and he was even slightly perplexed. Its frustrating because I know exactly what is happening, but can't figure out why. Something is giving a signal as always on because of the short, so as soon as I start up the car it overheats the circuit breaker, causing it to trip. There is constant power flowing to it, so therefore no resistance, and no reset. I tried unhooking the sunroof and mirrors to see if either of those could be doing it, but to no avail.
'98 V70
- 13 Replies
- 2285 Views
Last post by TheRev813
- 24 Replies
- 3021 Views
Last post by Madso
- 1117 Views
Last post by precopster
- 10 Replies
- 2425 Views
Last post by beardedbmx
- 2476 Views
Last post by kklepack
