XC70, 2002, remove lower radiator hose.
I can't see the lower radiator hose clamp at the radiator. Something must have to be removed to uncover the clamp. Can you tell me what and how to do it?
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
There's an air baffle that has to be removed under the radiator that runs the width of the car- one bolt (I believe it's 10mm) on each side...then after the plastic baffle is removed, you'll have access to the lower hose that's on the driver's side (passenger side if you're in the U.K.).
MadeInJapan
Well, they also clip in the front so it's not really only those two bolts that hold it in place.
