Misha,
In answer to your question on the oil trap box (why can't I just clean it up?). Mine was clogged and 1/3 or so full of a fairly hard black material. It might be possible to find a solvent that would dissolve the stuff. I didn't try because I had already ordered the new trap and hose kit. The hoses on mine were pretty brittle; at least one of them broke off when I removed it.
The same hard sludge was present in the engine openings the trap was connected to. I scraped the sludge off with a screwdriver, and verified the holes were open down to the oil sump by probing with a flexible line (an old hood cable).
Larry
question about pcv
Re: question about pcv
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Can you remember wat was the code on your oil separator box, 1271988 or 9146756?Is your car non-turbo?If it is non-turbo and have engine serial number after 330413 then you could help me to solve dilemma about which one will fit to my engine because both boxes have 2 hoses on up.
Guys at ipdusa telling me that box#9146756 will fit to my car,but that part is for engine# UP TO 330413,mine is 890337.
For engine#890337 box#is suppose to be(according to their catalog)1271988.
Looks just like this,but is says that is for '98 only,for s,v70,mine is '97 850.
- 1271988.jpg (120.71 KiB) Viewed 1532 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
My car is a 98 V70 AWD turbo and the oil trap looks like the one in the diagram, number is 1271988, so I can't help with the non-turbo. However, here are a couple of pictures of oil trap.
- misha
That's my point!
The diagram i posted above is for NON-TURBO model,box#1271988,and it fits to TURBO.
That's why i can't determine which one will fit to my engine!
The only way to know for sure is to remove intake manifold to see,but there's a big problem because shipment will arrive in about 2 weeks min.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Maybe you could see in there with a "mirror on a stick"? Try using a mirror and a strong light.
- misha
I'll try.It's my only option,to know for sure!
Thanks for advice.
Thanks for advice.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Good luck!
A mirror is also useful to see if the holes into the block are open.
- misha
Ok guys,i read somehow the number on my pcv box.It's 1271988
like the one for '98 s,v70 NON-TURBO-mine is '97 850 NON-TURBO!
I managed to read only smaller number,#927 which indicates pcv#1271988.Here's the picture:
I used my cell phone and video clipped with light on.Don't ask me how i did it!
My arm looks like i've been in fight with cats(all scretched up!)
BUT,i did it and i'm glad that i didn't order wrong pcv box.
P.S.At all on-line stores catalogues,pcv box#9146756 is indicated as for '97 850 NON-TURBO!And the pcv box#1271988 is indicated as for '98 ONLY
s,v70 b5254fs!
Hhhhhmmmm
Hhhhhmmmm
- pcv engine serial no 330413 and after(1271988).jpg (114.99 KiB) Viewed 1358 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I want to see the picture of you taking that picture
Seriously, good luck with the new oil trap.
- misha
Thanks!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1515 Views
Last post by rspi
- 14 Replies
- 1838 Views
Last post by woodycaldercloggs
