740gl 1989 spark plug wire order
740GL 1989 spark plug wire order
Like a true dope I was changing plugs and realized I needed to replace the wires also, but I didn't write down the order I took them off in. Looking at the engine from in front the car, the distributor is directly behind the 4cyl engine with 4 wire holes in a line from left to right. Does the first hole go to the first plug, second to the second, third to the third, etc? If not, can I get the correct order?
Kmaniac in California USA
- Year and Model:
I recently replaced the distributor cap on my 1986. If you take off the distributor cap, you will see that each wire plug is labeled with the cylinder number it supplies. But to save you the aggravation of pulling the cap, here is the order on the cap starting on the driver's side of the car: 2 - 1 - 3 - 4
Now, if the cap used on a 1989 is different than one used on a 1986, then all bets are off.
The cylinders on the engine are numbered sequencially with the one closest to the front of the car as #1 and the one closest the firewall as #4.
I hope this helps.
I hope this helps.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
1986 740 GLE
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Chris, you win the bet again!
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 3077 Views
Last post by Roger_850T
- 643 Views
Last post by 93Regina
- 3903 Views
- 1952 Views
- 12 Replies
- 6656 Views
Last post by mrbrian200
